89 CRX Si With B18b1 swap. Need help with wiring harness & ECU
Old Feb 22, 2008 | 12:07 PM
fracas's Avatar
Default 89 CRX Si With B18b1 swap. Need help with wiring harness & ECU
Picked up a 89 CRX Si With B18b1 swap. Has all OBDO parts on the longblock. Car was running but the *** hat that had the car before me hacked up the Engine haness. So I was wanting to know what year harness's I need. I know that a 89 Crx would be best. But I can pick up a 90 Teg harness in the morning. Just wanted to know if I could use it or now and if it would be plug and play.
Also need to know what ECU to use on this set up.
Old Feb 22, 2008 | 03:11 PM
fracas's Avatar
bump
Old Feb 22, 2008 | 05:39 PM
ant$missShift's Avatar
Default Re: (fracas)
teg harness wont work.. u can run a pr4 ecu
Old Feb 22, 2008 | 08:59 PM
fracas's Avatar
ttt
Old Feb 23, 2008 | 07:33 AM
fracas's Avatar
Bump!!! Guess I need a CRX Si harness from a 88-89????
Old Feb 23, 2008 | 08:33 AM
Crx Jimmy's Avatar
No just an 89 harness, 88s are different( I think the resistor box has a different connector. might work with a 88 harness and a 88 box?), you should not have to do any wiring it should plug and play, only the vtec motors need extra wires added.
Old Feb 23, 2008 | 09:38 AM
fracas's Avatar
ok thats what I wanted to hear. Thank for the input guys. Honda-tech and the members here Rock!
jdmsuckah
Sep 2, 2010 01:35 PM
CRX EF 88
Mar 19, 2008 07:42 PM
YOUR MOM
Nov 4, 2007 06:45 PM
chongfa_209
10
Jan 1, 2007 09:13 PM
crxracerr69
Jul 13, 2002 02:59 PM
