transmission is shifting hard and rough need help!!!
Old Feb 22, 2008 | 11:53 AM
iNDyCRX's Avatar
Default transmission is shifting hard and rough need help!!!
i was just wondering why this could be i already changed my tranny fluid what should i do and it sucks cuz i realy cant down shift either without the mother f-er grinding
Old Feb 22, 2008 | 02:10 PM
gursh d's Avatar
Default Re: transmission is shifting hard and rough need help!!! (iNDyCRX)
what tranny fluid did you use?
I would recommend getting some GM synchromesh tranny fluid. It doesn't necessarily fix the grinds, but more or less hides them. I would try that first.
Unfortunately, to fully repair grinds, your more than likely going to have to do a transmission rebuild.
Old Feb 22, 2008 | 02:25 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: transmission is shifting hard and rough need help!!! (gursh d)
Taking your 2-4 gears out and scuffing the gear cones will probably alleviate most of the grinding you are having.
as gursh said, to fix the problem, you are probably going to have to take the trans out and open it up to see whats going on.
Old Feb 22, 2008 | 02:31 PM
AnonymousSquid's Avatar
how old is your clutch?
Old Feb 23, 2008 | 07:51 AM
1kleenef's Avatar
Default Re: (AnonymousSquid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnonymousSquid &raquo;</TD></TR><TR><TD CLASS="quote">how old is your clutch?</TD></TR></TABLE>
check ur clutch prolly a worn clutch not engaging fully
Old Feb 23, 2008 | 08:12 AM
~sp33~'s Avatar
EFB055
Or try adjusting the cable.
Old Feb 23, 2008 | 08:20 AM
I CRX I's Avatar
get a flash light and take a look at the pedal assembly it may be cracking on you. or just look at you pedals, is the clutch pedal a good amount futhur then the brake?
Old Feb 23, 2008 | 08:22 AM
HondaHeddie's Avatar
Default Re: (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">Or try adjusting the cable.</TD></TR></TABLE>
by far the easiest test
no clutch is easier to adjust than the rex's
just reach down the where the plastic nut is (it is made to adjust with your hand) pull up just a little to get the nut to move over the lock nub and tighten it till you have no more that 1/2 inch of play on the clutch pedal.
this assumes you dont have a custom clutch, if so look up the clutch plate mfgr recommendation
Good luck I hope it is just clutch wear
Old Feb 23, 2008 | 08:31 AM
Crx Jimmy's Avatar
Default Re: (HondaHeddie)
sounds like you need to adjust the cable. you probably need to tighten it a bit
lisajasmin
Jun 4, 2008 04:56 PM
killyourscene
Honda Civic (2006 - 2015)
39
Jan 27, 2008 09:21 PM
BlackLudeSR
Jun 21, 2007 01:50 PM
phoshizzle88
May 17, 2006 10:39 PM
andrewasf77
Jun 19, 2003 07:32 PM
