ls ? about gsr belt and pump
Old Feb 22, 2008 | 07:34 AM
natecivic92's Avatar
Default ls ? about gsr belt and pump
I have a built ls b18b1 I am getting ready to put the water pump and timing belt on my build.I have the ls head with crower cams and crower adjustable cam gears The engine has been balanced the crank,flywheel,and such for higher revs I was wondering if I could run the gsr 22 teeth water pump and timing belt with the other stuff ie crank pulley cam gears and such being ls.....?Also the Gates timing belt anyone run one....
Old Feb 22, 2008 | 08:18 AM
ctr83's Avatar
Default Re: ls ? about gsr belt and pump (natecivic92)
you can use gsr water pump but you have to run the gsr timing belt and the cam gears and crank gear are the same as the ls.
so gsr water pump = gsr timing belt
Old Feb 22, 2008 | 08:43 AM
bigbadboy's Avatar
if your doing all that and revving higher you might as well also use the GSR oil pump
Old Feb 22, 2008 | 08:59 AM
ctr83's Avatar
Default Re: (bigbadboy)
vtec oil pump wouldn't hurt.
Old Feb 22, 2008 | 10:28 AM
Cool will the ls pump or the gsr pump over all keep my gt35r turbo ls cooler??
Old Feb 22, 2008 | 10:53 AM
ctr83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by natecivic92 &raquo;</TD></TR><TR><TD CLASS="quote">Cool will the ls pump or the gsr pump over all keep my gt35r turbo ls cooler?? </TD></TR></TABLE>
what do you mean cooler?? the water lines will keep the turbo cooler.
Old Feb 23, 2008 | 08:33 PM
I mean the engine do you all think the gsr or ls pump will do better keeping the car cool on the street
Old Feb 23, 2008 | 09:13 PM
bigbadboy's Avatar
no just better oiling specially at high RPM's
shortyz21
Nov 12, 2006 08:38 AM
JR Integra
May 3, 2004 04:17 PM
BoOsTiN Dc2
Feb 7, 2004 02:32 AM
GDM Z28
10
Aug 19, 2003 10:32 AM
tegasaurus
Aug 10, 2003 01:07 PM
