Tried searching, quick help
Old Feb 22, 2008 | 07:03 AM
team703's Avatar
Default Tried searching, quick help
Tried searching before i decided to ask, And when i said tried searching i tried a 100 times with different wording, but i was wondering if anyone Has a link to what size fuel injectors i can use in a 94 civic. I have a 94 ex with a Ls motor, and it is also turbo but i have yet to drive the car because i am wanting to upgade from the stock injectors. I do not need rc injectors or want to do the dsms with a resistor box. So my question is wht year prelude injectors will work and what is the size of the injectors? I am really just hoping someone has a link for future purposes of stock honda/acura fuel injector cc's and whether they are peak and hold or saturated. Thanks fellas if anyone can help, just a guy on a budget. And the reason why i want to use prelude injectors is because somewhere on this site i found that prelude injectors are bigger then stock civic or integra injectors. And i also scanned rc's website for info but didn't see anything
Old Feb 22, 2008 | 07:06 AM
crazyguy's Avatar
Default Re: Tried searching, quick help (team703)
for all i know. b and d series injectors are the same. obd wise might be different
Old Feb 22, 2008 | 08:35 AM
Jakester9500's Avatar
Default Re: Tried searching, quick help (crazyguy)
have you looked into buying a set of dsm injectors at all? they are pretty cheap and should work for you
Old Feb 22, 2008 | 08:51 AM
EG_Warped's Avatar
Default Re: Tried searching, quick help (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">have you looked into buying a set of dsm injectors at all? they are pretty cheap and should work for you</TD></TR></TABLE>
x2
Old Feb 22, 2008 | 09:02 AM
team703's Avatar
Default Re: Tried searching, quick help (EG_Warped)
yeah i have thought about dsms, but like i said, i thought i had seen where the prelude 5th gen injectors were like 290cc and the stock civic/integras were 220cc.And i am trying to avoid a resistor box and don't want to buy expensive injectors yet.
Dave2094
Jul 13, 2008 08:17 AM
si90rex
Sep 8, 2006 05:33 AM
jdmb16ahybrid
Nov 5, 2002 06:50 AM
