Winter tire size???
Old Feb 22, 2008 | 06:15 AM
GeniusTech's Avatar
Default Winter tire size???
Is 205/65QR16 a good size winter tire for my circuit 10 rotas? They are Blizzack WS-50s I have to use the rotas cuz the front breaks are upgraded and bigger so I cant use steelies
Old Feb 22, 2008 | 08:17 AM
A lil 2.3l action's Avatar
Default Re: Winter tire size??? (GeniusTech)
those tires are good... as long as they have a good winter rating and have tread then your good
Old Feb 22, 2008 | 08:35 AM
OSK Automotive's Avatar
Default Re: Winter tire size??? (A lil 2.3l action)
What car are they going on? I would try to run something skinnier if you can.
Old Feb 22, 2008 | 09:59 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeniusTech &raquo;</TD></TR><TR><TD CLASS="quote">Is 205/65QR16 a good size winter tire for my circuit 10 rotas?</TD></TR></TABLE>
Stickied at the top of this forum, where you'd have to be absolutely clueless to miss it, is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote"><FONT SIZE="4">Tires FAQ</FONT>
What size tires should I get?
<FONT SIZE="5">The proper size depends on your car, not just the wheels you are using. So if you want to ask what size you should get, let us know what kind of car you have (year, model, body style, version)!</FONT>
Old Feb 22, 2008 | 10:18 AM
GeniusTech's Avatar
Default Re: Winter tire size??? (nsxtasy)
its a 1990 crx si its dropped alittle bit but not that much. And I did look there but my question was specific becuase I have bigger calipers and cant use steelies and I went to tire rack and they dont have blizzaks in 205/45/16 the smallest they have is 205/55
Old Feb 22, 2008 | 11:35 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeniusTech &raquo;</TD></TR><TR><TD CLASS="quote">its a 1990 crx si its dropped alittle bit but not that much. And I did look there but my question was specific becuase I have bigger calipers and cant use steelies and I went to tire rack and they dont have blizzaks in 205/45/16 the smallest they have is 205/55</TD></TR></TABLE>
205/65-16 is MUCH too big for your car, and will almost certainly rub in your wheel wells, big-time. Same thing for 205/55-16. The best 16" sizes for your car would be either 205/40-16 or 195/45-16, but there aren't any studless winter tires available in those sizes. The closest you can come is 205/50-16, in which you can get the Michelin X-Ice (but not the Blizzaks). The X-Ice is a very good winter tire. However, even the 205/50-16 may rub; no guarantees it won't.
The problem with rubbing is that these tires are 20 mm wider AND bigger in diameter than your stock tire size; here are the diameters:
185/60-14: 22.74" (stock)
205/40-16: 22.46" (-1.3 percent)
205/50-16: 24.07" (+5.9 percent)
205/55-16: 24.88" (+9.4 percent)
205/65-16: 26.49" (+16.5 percent)
Now you can see why both the 205/65-16 and the 205/55-16 are WAY too big.
Remember that even with the 205/50-16, your speedometer and odometer are going to be off by 6 percent. And even that size may rub, especially on a lowered car. But I don't see any way around it, with winter tires.
Your other alternative is to get all-season tires, which (as you probably know) won't grip quite as well in winter as winter tires, but at least you can get them in the size you need, without being forced to get oversized tires that might rub. If you decide to go this route, I recommend the Kumho ASX, which is available in 205/40-16.
If I were stuck in your situation, I would go with the ASX in 205/40-16.
HTH
PI$TOL
May 17, 2008 05:25 AM
Scottyk6
Feb 14, 2008 07:17 AM
No2Pencil
Apr 6, 2007 06:47 PM
RGoose18
Dec 8, 2005 10:31 AM
ludewithanh22
Jun 2, 2005 11:04 PM
