Will these dimentions fit in the second bay of my radio?
Old Jul 5, 2002 | 10:03 AM
hooptie157's Avatar
Default Will these dimentions fit in the second bay of my radio?
Dimention : 185(W) X 54(H) X 250(D) mm
can anyone help with this. This is a 01 ITR, will something with these dimensions fit in the second bay under the stock radio?
Old Jul 5, 2002 | 11:59 AM
sgT's Avatar
sgT
Default Re: Will these dimentions fit in the second bay of my radio? (hooptie157)
doubt it. Its a 3/4 DIN space
Old Jul 5, 2002 | 12:02 PM
Tommy_Gunns's Avatar
What did you get or gonna get?
Old Jul 5, 2002 | 12:05 PM
hooptie157's Avatar
Default Re: Will these dimentions fit in the second bay of my radio? (sgT)
so thats a no???
Old Jul 5, 2002 | 12:08 PM
hooptie157's Avatar
Default Re: Will these dimentions fit in the second bay of my radio? (Tommy_Gunns)
Key Specifications/Special Features:
Special features:
7"wide color TFT LCD monitor
8bit Micro Controller installed
High resolution, low reflection TFT LCD panel
All function, Electronic control enable(Power, Mode Volume, Setup, Contrast, Brightness, Color, Tint)using card type IR remote control.
OSD Back Ground for All function
4 languages OSD(English, Germany, Japanese, Korean)
5 Screen Mode (Full, Wide, Normal, Cinema, Zoom)
Auto TV System(NTSC, PAL, AUTO)
1W Speaker Install
A/V1, A/V2 Input Jack
Low Power Consumption(Max 750mA DC 12V)
Key Specifications:
TV System: NTSC/PAL Free Mode
Power supply source: DC12V or AC/DC Adaptor
Power consumption: 9.0watt
LCD: 7" wide Color TFT LCD
Resolution: 1,440(W) x 234(V) DOTS
Brightness: 300cd/m x m
View direction: 12 o'clock
Operating temperature: -15°c to 60°c(+5°c to 140°c)
Storage temperature: -30°c to 85°c
Dimension: 197(W) x 121(H) x 31(D) mm or 7.7(W) x 4.7(H) x 1.2(D) inch
Weight: 0.55kg(1.2lbs, excluding monitor bracket
and
Special features:
Dolby digital 5.1 channel(silver-option), Down mixed 2 channel (3D Sound)
Dolby Prologic Surround, DTS stream output-DC 12V, IR remote/IR receiver module
Full compatibility with DVD, DVD-R, VCD, SVCD, CD, MP3, CD-R, CD-RW
TV ASPECT 4:3, 16:9
Zoom x2, x4, x8
Key Specifications:
Available DISC : DVD, DVD-R, VCD, SVCD, CD, MP3, CD-R, CD-RW
Video System : NTSC, PAL
Video Decoding : MPEG2
Audio Compression :AC3
Power Source : DC12V
Power consumption :18W
Operating Temperature : 0¢ªC ~ 40¢ªC
Storage Temperature : -20¢ªC ~ 60¢ªC
Weight : 1.8 Kg
I have this stuff that I got for a really good price, I probably gonna sell for some sort of money but I wanted to know if it would fit cleanly in the dash
Old Jul 5, 2002 | 12:12 PM
I'm pretty sure you can make it fit. Dremel is your friend.
Old Jul 5, 2002 | 12:15 PM
hooptie157's Avatar
no dremel, I may wanna sell the car is decent condition at some point, hey do any of you guys wanna buy this stuff
Old Jul 5, 2002 | 12:17 PM
o_Rage_o's Avatar
the tegs can fit one 1 DIN deck and a 1/2 Din EQ with a nice aftermarket plate. that's about it.
You can also prob find a 2 din mouting plate, or 1 Din with compartment for papers/glasses and stuff..
-Rage
Old Jul 5, 2002 | 12:20 PM
See, I never have this train of thought in my head cause I plan on keeping her (my ITR) forever. So I do whatever I feel like.
Old Jul 6, 2002 | 12:01 PM
hooptie157's Avatar
anyone
Old Jul 6, 2002 | 12:17 PM
Dr Pooface's Avatar
The solution is easy. Buy a generic aftermarket head unit mounting kit, and make it work with that. $20 max, and your stock stuff goes in your closet.
Old Jul 6, 2002 | 12:37 PM
hooptie157's Avatar
Default Re: Will these dimentions fit in the second bay of my radio? (Ddub)
I can make the face dimensions fit, BUT i wanna know about the depth, is there something back there that would cause it not to go fully in place??
Old Jul 6, 2002 | 12:48 PM
Rob :190:'s Avatar
stunna!
Old Jul 6, 2002 | 01:25 PM
Nope. If you can make it fit up front then it should fit in the back as well...at least from my memory. When you think about it, that tray they made under the radio is pretty useless...can't put anything in there unless you want it to fly out while your driving.
Old Jul 6, 2002 | 01:46 PM
hooptie157's Avatar
not in the tray, with the tray out
Old Jul 6, 2002 | 05:29 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
I have the Eclipse 7002 fold out TV screen and a CD deck on the lower half. You can make it fit. You may have to do what I did though and superglue the surrounding casing. When I would hit the gas, the radio would be in my lap. Superglue is your friend. Just don't be like American Pie 2
[Modified by RealTypeR, 2:29 AM 7/7/2002]
Old Jul 6, 2002 | 05:43 PM
yes that's what I meant.
I used to have nothing there...no tray or radio.
hooptie157
Sep 14, 2002 02:36 AM
hooptie157
Jun 24, 2002 01:01 PM
hooptie157
Jun 24, 2002 10:20 AM
