CRX motor and transmission swap???
Old Feb 21, 2008 | 05:02 PM
2zwudz's Avatar
Default CRX motor and transmission swap???
I am thinking of doing a motor/transmission swap on a 1990 CRX. It presently has a automatic transmission. When I do the motor swap I would like to put a 5 speed in it . What Honda cars would be a good choice to provide the correct equipment needed to do this swap? I am only wanting a good dependable car not a track car or show car just a depenable set up for my crx.
Thanks
Mark
Modified by 2zwudz at 4:28 AM 2/22/2008
Old Feb 21, 2008 | 06:14 PM
StorminMatt's Avatar
Default Re: CRX motor and transmission swap??? (2zwudz)
That depends on the motor. For D-series motors, a 1988-1991 Civic manual transmission is easiest to use. Alternatively, you can use aftermarket mounts in order to adapt a 1992-2000 hydraulic transmission. But these mounts are relatively costly. For B/H/F/K motors, you need to use a transmission for the same series of motor (although H and F motors and transmissions are cross-compatible). As a side note, I should also say that there are adaptor plates for H/F motors so that they can be used with B/D transmissions.
Old Feb 22, 2008 | 02:19 AM
whiteknightef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2zwudz &raquo;</TD></TR><TR><TD CLASS="quote"> I am thinking of doing a motor/transmission swap on a 1990 CRX. It presently has a automatic transmission. When I do the motor swap I would like to put a 5 speed in it . What Honda cars would be a good choice to provide the correct equipment needed to do this swap?
Thanks
Mark</TD></TR></TABLE>
The same car you have but in a 5-speed.
crxproject87
Mar 27, 2008 07:06 AM
4thgenlude
Aug 28, 2005 03:29 PM
12SecHatch
Oct 8, 2003 12:15 PM
Type-ARR
Aug 5, 2001 05:58 PM
