skunk 2 tb getting stuck
Old Feb 21, 2008 | 04:07 PM
dreamreaperx's Avatar
Default skunk 2 tb getting stuck
as the title says i had a skunk 2 tb and mani installed today and as i go to drive it the throttle body is getting lightly stuck when it is closed (without accelerating)... the car feels good once i get past that point where it is stuck but is there anything i can do so it won't stick?
Old Feb 22, 2008 | 11:38 AM
geramy's Avatar
adjust the screw for the butterfly. Its easier to do with the TB off the car.
it is in in the instructions that came with the TB if you have them
-G
Old Feb 22, 2008 | 11:48 AM
would that be the same screw to adjust idle? or is this screw somewhere else on the tb?
Old Feb 22, 2008 | 02:20 PM
QUIETP_11's Avatar
Default Re: (dreamreaperx)
no, different.
the screw controlling the throttle plate return is tiny and nearly impossible to adjust while it is on the car. It's easiest to take the TB off then adjust it accordingly.
Old Feb 22, 2008 | 02:26 PM
QUIETP_11's Avatar
Default Re: (QUIETP_11)
It's not a Skunk2 TB, but the basic setup is the same regarding the location of the throttle return screw. It is the small bolt/nut located on the bottom side of the TB Pulley
hope that helps
Old Feb 22, 2008 | 09:36 PM
thanks it helps, but it seems the throttle plate fits too tight inside the throttle body so how would adjusting the bolt help? could you shave a little of either the butterfly or the throttle body so it opens up more smoothly?
Old Feb 23, 2008 | 06:38 AM
geramy's Avatar
adjusting the screw will stop the butterfly from getting stuck. it keeps it a very slight angle. You need to remove it, adjust the screw so that it looks completly closed but does not stick. open it and let it snap shut a few time to make sure it will take a few adjustments to get it just right but thats what you have to do.
Old Feb 25, 2008 | 06:56 PM
ok, i tried adjusting the screw today while on the car while a buddy of mine held the throttle cable tight so i could work....i tried loosening to see if that would help but once the screw is loose it's very loose..not sure if that was the way i was supposed to go so i retightened. should i go tighter than what it was originally? how does the butterfly screw adjust lefty loosey less tension on throttle plate or other way around? need help resolving this issue please!!!
Old Feb 27, 2008 | 06:12 PM
bump
Old Feb 28, 2008 | 04:41 AM
QUIETP_11's Avatar
Tightening the small screw will open it slowly. Loosening that screw is doing the opposite of what you want.
green_eg_hatch
Jan 11, 2010 12:04 AM
meanshyguy
Sep 28, 2008 08:28 PM
ITR.#1446
Jan 7, 2004 11:04 AM
Al Bundy
Jun 26, 2003 09:56 PM
Squalo
Oct 25, 2002 09:55 AM
