overheating problem
Old Feb 21, 2008 | 03:10 PM
HellerDopeEK4's Avatar
Default overheating problem
my dads civic d16y7 overheats at idle, but its ok when driving... the fan is working but there was a little leak where the hose meets the top of the head, the radiator has 115,000 miles on it... what are the symptoms of a blown head gasket...does he need a new radiator.. anybody help us out..thnx we appreciate it alot...
Old Feb 21, 2008 | 03:14 PM
slambedcivic's Avatar
Default Re: overheating problem (dApEkLuV)
when its cooled down, take the rad cap off, start the car, and look for constant bubbling. thats a sign of a bad HG. drain the oil and see if its milkly/chalky colored. when the car is hot, see if the coolant is bubbling into the coolant overflow. and the best way, is a compression and/or leakdown test.
Old Feb 21, 2008 | 03:49 PM
scar96's Avatar
replace the engine temp sensor...it is located on top of the thermostat housing.
i had the same problem.
replaced everything and flushed 3 times.
at the end it was that stupid sensor.
save yourself the time and money and just get that sensor.
Old Feb 21, 2008 | 03:52 PM
Default Re: (scar96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scar96 &raquo;</TD></TR><TR><TD CLASS="quote">replace the engine temp sensor...it is located on top of the thermostat housing.
save yourself the time and money and just get that sensor.</TD></TR></TABLE>
if the fan runs, doesnt the temp sensor work?
E_F_9
10
Jun 18, 2012 08:14 PM
93 EG
10
Jun 28, 2007 11:51 AM
