Clicking noise when car is moving and not in gear.
There is a clicking noise coming from my transmission, when the car is in neutral, or in gear with the clutch pushed in. It only makes the clicking noise when the car is moving, and it gets louder with speed. But it doesn't make any noise when it's in gear or under acceleration. The transmission feels fine. I changed the tranny fluid with Gm Synchromesh, and the transmission bolt with a skunk 2 magnetic one, last weekend and it has made the noise since then. The transmission is from a 1998 gsr. Any ideas what this noise could possibly be? Thank You
could be the bearing in the transmission
not 100% sure on that but my friend with an ef has similar problem and was told that was wrong with it
i had that issue with my 93 civic and i had to replace the tranny. and the cv shafts, the shop i take my car to said the tranny was low on fluid and there was a issue with thte sync.
Well I found the problem! My skunk2 magnetic drain bolt's magnet was eaten by my transmission. The magnet part is sheared completely off. When I talked to a local shop the mechanic said that the shorter magnet is supposed to go in the tranny and the long one in the oil pan but on skunk2.com it says the contrary.
Which one is the correct bolt? What should I do now that there pieces of the magnet in my transmission?
corcoran_chris
Dec 11, 2008 10:07 AM
