oxygen sensor problems. cel 41.
Old Feb 21, 2008 | 12:02 PM
00fbp's Avatar
Default oxygen sensor problems. cel 41.
quick history:
Bought a 00 civic dx hatch back in 2003.
Got out of the honda scene and used the car as a commuter car.
This year i have to smog the car to register and unfortunately CEL 41 shows up.
So i go to inspect the oxygen sensor and this is what i found.
</img>
</img>
and i also broke one of the bolts for the heat shield while trying to remove it.
</img>
The sensor is also stuck. I cant take it out.
My question is:
Is the crack in the manifold causing the code 41?
Will the CEL go away if i just change the sensor?
Do i have to buy a whole new manifold and cat?
Thanks in advance guys.
Old Feb 21, 2008 | 12:08 PM
crazyguy's Avatar
Default Re: oxygen sensor problems. cel 41. (00fbp)
i dont think cracked exhaust manifold will caust the CEL on o2 sensor but u will need a new exhaust manfiold for sure.
Old Feb 21, 2008 | 12:18 PM
00fbp's Avatar
Default Re: oxygen sensor problems. cel 41. (crazyguy)
is the exhaust manifold and the TWC Coverter one piece on the d16y7?
if so will i be able to buy a used one or do i have to buy a brand new one since its connected with the cat?
Old Feb 21, 2008 | 12:21 PM
95sloweg's Avatar
Your gonna need a new manifold no matter what. Go buy a new one and if you cant get that o2 sensor off, then buy a new one and it should fix both problems.
Old Feb 21, 2008 | 12:26 PM
00fbp's Avatar
Default Re: oxygen sensor problems. cel 41. (95sloweg)
this sucks. i need to smog the car next month and i dont have enough cash to buy the exhaust manifold/cat right now. the sensor itself costs 93 bucks.
thats why i was wondering if the CEL was caused by the crack.
i was just going to change the sensor if that will take out the CEL so i can smog it. Then ill swap out the the manifold/cat later.
thanks for the quick replies.
Old Feb 21, 2008 | 12:55 PM
00fbp's Avatar
bump
or should i just register it as a non-op and swap a k20 in later. muahahah.
if only i was rolling in cash.
Old Feb 21, 2008 | 01:07 PM
Relic1's Avatar
41 = O2 heater = in no way related to the crack.
Old Feb 21, 2008 | 02:05 PM
00fbp's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">41 = O2 heater = in no way related to the crack.</TD></TR></TABLE>
oh ok. this is good news.
now i gotta find a way to remove and replace the sensor because it is stuck.
Old Feb 25, 2008 | 07:19 PM
sohckid00's Avatar
Default Re: (00fbp)
bro i got some good news for u i had to replace my sensor too on my 2000 civic ex and as far as the o2 sensor goes i got one new for ubber cheap.go to oxygensensors.com heres the exact link
http://www.automedicsupply.com...t=768
i got mine for 50.something shipped
there good and legitit took me like 4 days to recieve it
i got the cheapest one that u cut and connect to the plug connection so hope that helped on that
as for the crack ummm i dunno
Old Feb 25, 2008 | 07:28 PM
JustG's Avatar
What I think may have happened is that with the crack, the temperature around the sensor became too hot and over time could have burnt it out.
Instead of taking a chance with the new sensor, dont buy a new manifold, just run a quick bead with a mig welder. If you dont have 1, ask any shop to do it. Tell em you will give them $20 for 5 minutes of their time and you are groovin...
I had a crack in the manifold in kind of the same spot, right where 2 runners meet, on my AE86 corolla, I ran a bead and it was fine. And cheaper than a new set of TRD headers!
Old Feb 25, 2008 | 07:51 PM
hott95ej2's Avatar
Default Re: oxygen sensor problems. cel 41. (JustG)
that crack will also cause a lean reading too
Old Mar 1, 2008 | 09:50 AM
00fbp's Avatar
Default Re: (sohckid00)
Thanks for the link mang. their prices are really good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohckid00 &raquo;</TD></TR><TR><TD CLASS="quote">bro i got some good news for u i had to replace my sensor too on my 2000 civic ex and as far as the o2 sensor goes i got one new for ubber cheap.go to oxygensensors.com heres the exact link
as for the crack ummm i dunno</TD></TR></TABLE>
Old Apr 22, 2008 | 01:51 PM
manorfastlube's Avatar
hey guys im new and dont know how this works but i have a 1993 Civic CX 1.5L manual with a 41 CEL code I've cleaned all my connectors, checked for shorts to ground and replaced the hole system from the manifold to the PCM, im out of Ideas...
Old Apr 22, 2008 | 02:18 PM
Relic1's Avatar
Default Re: (manorfastlube)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manorfastlube &raquo;</TD></TR><TR><TD CLASS="quote">hey guys im new and dont know how this works but i have a 1993 Civic CX 1.5L manual with a 41 CEL code I've cleaned all my connectors, checked for shorts to ground and replaced the hole system from the manifold to the PCM, im out of Ideas...</TD></TR></TABLE>
41 = O2 heater
CX does not have O2 heater wiring nor O2 heater circuitry in the ECU.
You're obviously chipped (you should have mentioned that)
are you running the P05 or a VTEC ECU with your swap?
Old May 6, 2008 | 06:08 AM
team_sol06's Avatar
does a bad o2 sensor affect MPG
Old May 6, 2008 | 07:02 AM
Relic1's Avatar
Default Re: (team_sol06)
yes
hybrid90
Apr 23, 2012 02:47 PM
00fbp
Feb 22, 2008 12:08 PM
DAP97SI
15
Jan 15, 2008 10:52 PM
Rubixcu7
Aug 18, 2005 12:51 PM
