Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Tanabe tower bar + intake pipe, enought space?
Old Feb 21, 2008 | 11:37 AM
kABLiuks's Avatar
Default Tanabe strut bar + intake pipe, enought space?
So i just bought and installed Tanable tower bar aand i touches stock air filter box. So the first question would be, is it okey or it my crap instalation?
Next, if i try to install new intake system, no matter short-ram or cold intake, will it have enought space to go with my tower bar or not?
Modified by kABLiuks at 12:05 AM 2/22/2008
Old Feb 21, 2008 | 11:43 AM
daddy's Avatar
Default Re: Tanabe tower bar + intake pipe, enought space? (kABLiuks)
Some pictures would be helpful. Also, better english would help some to.
Depending on how much it is hitting your airbox will determine if it will cause problems.
as far as using a new air intake it will depend on which you get. every one is different.
Old Feb 21, 2008 | 11:58 AM
Curiouz_G's Avatar
location says hes from Vilnius, Lithuania. I would say his English is pretty decent
I know the Neuspeed bar wont get in the way with the intake so look at some pictures in the picture thread and see if its similar to the Tanabe one. I think you mightve installed it upside down though.
Old Feb 21, 2008 | 12:05 PM
daddy's Avatar
Default Re: (Curiouz_G)
wow didnt even notice that. my apologies to the OP
Old Feb 21, 2008 | 12:41 PM
fitfreak3's Avatar
Default Re: (daddy2be)
I think your only option would be the Injen intake system unless you use the Nuespeed strut bar or even an RSX Type S strut bar(OEM) then your possibilities should be endless
Old Feb 21, 2008 | 10:32 PM
kABLiuks's Avatar
I'll try today unscrew strut bar, widden and put it back, that should do the trick. And for intake, I'll try to compare many picture and maybe that will help, but still its a bit of a loltery, so if some one has any strut bar + intake, please let me know what combo that is. Thanks guys
Old Feb 21, 2008 | 11:06 PM
kABLiuks's Avatar
here I found something
http://www.hondacivicforum.com...C.jpg
aint very easy to fit....
alex_vang
11
May 25, 2010 05:49 PM
asonunlque
Apr 18, 2008 08:48 PM
huumanshadow
11
Apr 30, 2007 07:02 AM
B18Redline
Jan 16, 2005 07:54 AM
