skunk2 manifold on gsr
Old Jul 5, 2002 | 07:56 AM
civteg1's Avatar
Default skunk2 manifold on gsr
was wondering if anyone out there could help me out I was tinking of buying a skunk2 manifold from a freind for a gsr but all I have done to my engine is aem intake, dc header,clutch, flywheel, exhaust, I also have the stock cams tuned, so my question is will the manifold give me any gains without cams or a turbo. Or will I loose power
Old Jul 5, 2002 | 08:01 AM
Thrashin's Avatar
Default Re: skunk2 manifold on gsr (civteg1)
yes you will see a big increase in power. the stock gsr manifold sucks. i had one on my last car and it was a big improvement, just make sure you get an ITR throttle cable and the little pulley for it.
Old Jul 5, 2002 | 08:08 AM
civteg1's Avatar
Default Re: skunk2 manifold on gsr (thrashin)
why can't you sue the gsr cable
Old Jul 5, 2002 | 08:17 AM
navin's Avatar
becuz skank2 is a replica of the ITR intake mani. Thinking about it, I might just go ahead and get the skank2 while the motor is out.
Old Jul 7, 2002 | 06:17 PM
2.2L EH2's Avatar
Default Re: skunk2 manifold on gsr (navin)
i think you gonna need to skunk2 rechipped ecu. when you get skunk2 mani. because the ecu will read it. it'll still think the secondary butterfly is still there. and the skunk2 doesn't have a secondary butterfly.
Old Jul 7, 2002 | 06:19 PM
(teh)H2OUUP2's Avatar
Default Re: skunk2 manifold on gsr (92_GSRhatch)
It runs w/o the vacuum solenoid for the secondaries, and it throws no codes.
Old Jul 7, 2002 | 06:52 PM
TurboBumblBee's Avatar
you will see a big increase in high end power.. you WILL lose some low end power tho.. roommate has it on this swap and it helped out a lot.. as for the itr throttle cable and pully thing they make it easier but we have his working w/ NO problems at all using the gsr parts..
lazii_boi08
May 2, 2011 10:49 AM
darkenedsol
Mar 23, 2010 12:37 PM
kpop
Jun 19, 2006 08:43 AM
tomlinson619
Apr 14, 2006 04:26 PM
