5th Generation, what is the model? KH, KG, KE?
Old Feb 21, 2008 | 06:05 AM
billyrusa's Avatar
Default 5th Generation, what is the model? KH, KG, KE?
I have a 1994 Accord station wagon. On the service manual, the electrical diagrams are different for different models. So far, I noticed there are 3 different models on the service manual, KH, KG, KE. How can I determine which mode my car is?
Old Feb 21, 2008 | 06:53 AM
TheMuffinMan's Avatar
He knows where you live!
wat?
Chassis code is CE
Models would be LX or EX
Transmissions would be KA5MT, KA4AT, KL4AT, KL5MT.
You're in Georgia so my Guess is it's the KA4AT with an LX or EX
Old Feb 21, 2008 | 07:07 AM
billyrusa's Avatar
Default Re: (TheMuffinMan)
Yes, you are right. My car is LX KA4AT. However, when I check the electrical circuit diagram on the service manual, the manual always gives three different schematics labeled as KH, KG, KE model.
Old Feb 21, 2008 | 07:10 AM
Hmm, I can honestly say I've never seen that before. What manual?
And what specific electronics?
Old Feb 21, 2008 | 07:23 AM
billyrusa's Avatar
It is a CD7_CD9 service manual with total 1379 pages. I am looking at page 1153 for gauge assembly circuit diagram. Between the oil pressure indication light and the oil pressure switch, there is a connection to an integrated control unit for KH model. I want to know if my car has this control unit for oil light problem. I am hoping my car is not KH model because I do not want to check this integrated control unit.
Old Feb 21, 2008 | 07:33 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: (billyrusa)
yeah, I believe that and some other things are different in those downloadable PDF manuals as compared to the printed manual you would buy from Helm Inc.
Old Feb 21, 2008 | 07:34 AM
billyrusa's Avatar
I found the location of the integrated control unit from the manual. It is attached to the underdash fuse/relay box. I will check if my car has this unit when I go back home.
Old Feb 21, 2008 | 07:55 AM
billyrusa's Avatar
Correction. The integrated control unit exists on each model. The connection to the unit is 16P for KH model and 8P for KG and KE model. For KH model, there is a oil pressure light flasher inside the unit.
Old Feb 22, 2008 | 06:29 PM
brose's Avatar
I purchased a 94-97 CD ROM service manual off eBay. It included data for <U>all </U> Accords worldwide. To answer your initial question, KH refers to USA Accords. KG, KE, KZ, KS are European Accords. KQ is Australian, KY is Saudi Arabian. Unsure where Canada and Mexico fit, I assume they're also KH.
Old Jun 8, 2008 | 06:10 PM
teg your it's Avatar
Default Re: (brose)
in KL4AT and KA4AT what does the KL and KA mean?
Old Jun 8, 2008 | 06:40 PM
propwdialogue's Avatar
Default Re: (teg your it)
Don't know what the acronyms stand for specifically, but the KA is for 49 state emissions, and KL is for California emissions. (KH is for high altitude FYI)
Old Oct 29, 2008 | 04:32 AM
Saper's Avatar
Default Re: (brose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brose &raquo;</TD></TR><TR><TD CLASS="quote">KG, KE, KZ, KS are European Accords.</TD></TR></TABLE>
Yes, but how can I determine which model my car is: KG or KE? There are many diffrences in the service manual ie. in weight:
KE: 2.0i LS M/T - 2910 lbs
KG: 2.0i Ls M/T - 2855 lbs
And there's no explanation in the service manual or even in the internet
Old Oct 29, 2008 | 05:06 AM
Assuming its how the US ones are it should be in the car's VIN number. Or the European equivalent.
Old Oct 29, 2008 | 06:15 AM
Saper's Avatar
Which part of the US car's VIN number refers that the model is KH?
Old Sep 28, 2010 | 06:45 AM
pjschmitt's Avatar
Default Re: 5th Generation, what is the model? KH, KG, KE?
Well it took me a few minutes to find this but here it is:
NOTE: Abbreviations for USA, European and other model Honda Accords are listed as KH, KG, KE, KZ, KS, KQ and KY in this manual.
KH = USA, Canada & Mexico Accords.
KG, KE, KZ, KS = European Accords.
KQ = Australian Accords.
KY = Saudi Arabian Accords.
I know this is an old thread, but I search old threads for answers and this is one time I think adding info to an old post is totally appropriate.
Old Sep 28, 2010 | 05:47 PM
CRZ1's Avatar
pjschmitt,
Thanks a lot. I almost hit a deer last night. The deer hit my accord driver side front side marker light plastic cover. When I checked the pdf manual yesterday, confused by the KH, KG etc. Now I understand.
Old Sep 3, 2012 | 11:57 PM
N1NJ4574R's Avatar
just curious if you could tell me where you found this out and if not should these codes apply to preludes and other models as well?
Old Sep 4, 2012 | 03:31 AM
Brice.Hayden's Avatar
I doubt he'll respond as this thread is more than 2 years old
Clevor
Nov 4, 2013 11:22 AM
tt
Feb 17, 2010 03:14 PM
douellett
Honda Civic (2001 - 2005)
Jan 30, 2008 10:42 PM
lastlude2k1se
May 2, 2006 09:46 AM
lowRIDAH
Sep 2, 2004 09:51 AM
