some way to REALLY tighten down the stock seatbelt?
Old Jul 5, 2002 | 07:18 AM
serious's Avatar
Default some way to REALLY tighten down the stock seatbelt?
does anyone know of some way i could tighten my seatbelt down a lot when i want to? i don't want new seats or a harness, but i'd like to be able to secure myself to the seat when i want to.
Old Jul 5, 2002 | 08:27 AM
RyanR's Avatar
Default Re: some way to REALLY tighten down the stock seatbelt? (serious)
Pull the part that goes across your chest as tight as possible. When you start taking the turns, it should lock and hold you in. Won't work nearly as well as a proper harness, but it works.
Old Jul 5, 2002 | 08:47 AM
rpr's Avatar
rpr
Before I put in the harness, I used to use the sliding seat trick. Slide the seat back a couple notches, push back into the seat, pull the shoulder belt back (up) so it's as tight as possible, and give it a quick jerk down so it 'locks'. While still holding it locked, slide your seat forward. If you do it right, you will be pinned in the seat. The only problem is if you have it set on the borderline and you relax in the seat, it may 'unlock'.
It takes a few tries to get it, but it does work.
Old Jul 5, 2002 | 09:28 AM
keithv's Avatar
Default Re: some way to REALLY tighten down the stock seatbelt? (rpr)
i do this whenever i auto-x. i've gotten it so tight across my chest it was hard to breathe.
Old Jul 5, 2002 | 12:01 PM
CRXSi90's Avatar
Would this seat sliding trick work in my '90 CRX Si? I tried, but I could not get the seatbelt to lock. Maybe I'm just a weakling, huh?
Old Jul 6, 2002 | 10:02 PM
CRXSi90's Avatar
Default Re: some way to REALLY tighten down the stock seatbelt? (CRXSi90)
come on, has anyone done this in a 90 or 91?
I'll take it as a NO if nobody responds this time.
help a fellow honda owner
Old Jul 6, 2002 | 10:05 PM
89 CRX SI's Avatar
you gotta pul short and really quick not nessicarly hard but wuick accel. just a short quick burst as if someone rear ended you at 5 kph.make sure its retracted enough
Old Jul 8, 2002 | 09:17 PM
travis's Avatar
One addition to this idea. Before you clip the seat belt in (while your seat is slid back), twist the end of the belt around once or twice and then clip it in. Lock it (yank), and slide your seat forward. This will help keep it locked if it gets a chance to "relax" a little.
Old Jul 8, 2002 | 09:49 PM
marty's Avatar
Zip ties
Just get harnesses even though you dont like em. Stock seatbelts cannot be tighten down securely at will it has to be in some way forced locked.
EFin' Kyle
May 20, 2005 12:02 PM
95dc2
32
Jan 29, 2004 08:08 PM
Tyson
14
Aug 9, 2002 11:10 PM
Rob Dizzle
24
Aug 3, 2001 09:11 AM
