jdm ls/vtec boosted, porsche riviera blue
994, 180ish on the body, 650 on the motor. all done by autolab(louisville, ky) with receipts for eveything. rebuilt title. the story behind that is my minor accident on the drivers side. expletiveed up the headlight and core support, no frame damage at all, have pictures of the accident. so thats why i did the jdm conversion. the core support is replaced in the conversion as im sure you know so there was no harm done to the body at all. during the conversion, the doors foward were painted so that it would be a nice blend. the entire car is painted porsche riviera blue, including trims, engine bay etc. lowered on ground control coil overs.
oem type r rear spoiler
new ls tranny with 30k miles, no grinds
act 6 puck, type r flywheel
some bbs offbrand wheels gunmetal, polished lip, 17"
type r rear seats
del sol fronts
alpine type r component speakers
jvc head unit, nothing too cool
dc front strut bar
98 rear conversion, bumper has a dent in it, might be able to be popped out, havent tried, tails look great
skunk 2 camber kit
new in last 650 miles:brake rotors and pads, starter, alternator, battery, alignment, plugs and wires.
new motor stuff:
cam seals, oil pan gasket, oil pump o ring, intake gasket, valve cover gasket, oil pump, and rear main seal.
arp head studs, arp main and rod bolts so you can rev to 8500 with the ls bottom
hasport motor mounts
eagle rods
je pistons, 81.5 mm
spun and blanced crank
cometic head gasket
block was honed clean to fit pistons
head was machined
spark plugs
injectors
the pistons are 9:1 compression, when the ls/vtec is done it raises it to 9.7 to one on average. the head has been machined to an amount that adds about .5
so the estimated compression i would guess is around 10.2:1. ive had the kit off before and it still pulls pretty hard. i would compare it to a type r with IHE, maybe a little faster. its nice that it revs to 8500 too. i would have the car retuned before i sold it with the kit off if the buyer wanted. right now the hood isnt painted because i just put it on, its dark blue in color. i can have it painted top and bottom for 200 bucks. im going to try and take pictures of the car now tomorrow.
here are the older pictures
http://www.cardomain.com/id/brandnewman16
TURBO
turbo kit
greddy 18g turbo, great, full boost by 3400
vtec at 4600
presicion 780 injectors
prescion intercooler
custom pipes by autolab
log manifold
externally welded tial 38 mm wastegate, greddy is internally wastegated
7,9,12 lb springs
blitz bov
golden eagle ls/vtec kit
p06ecu, crome tuned
all other piping, couplers etc
lotta stuff, i dunno
asking 9500 with the kit, or 8k without it
brandnewman16@hotmail.com
aim:brandnizzles
type r rear seats
del sol fronts
dc front strut bar
skunk 2 camber kit
new motor stuff:
eagle rods
je pistons, 81.5 mm
cometic head gasket
head was machined
spark plugs
injectors
TURBO
turbo kit
vtec at 4600
log manifold
7,9,12 lb springs
blitz bov
p06ecu, crome tuned
aim:brandnizzles
pictures are at http://www.cardomain.com/id/brandnewman16 and more to come of interior and all tomorrow
theres more on http://www.cardomain.com/id/brandnewman16. ill take some more of everything and post them tom, including wheels, interior and all. car is pratically ding free.
B18C Turbo
Sep 14, 2006 08:47 PM
