Dash swap
If you found posts confirming the CRX Dash moving into the 4-Door with little to no modification, then that means the reverse should be true. If that's the case then you can use it in your Hatch because it's definitely known that the Hatch and CRX Dashboards are swappable without hangups providing a complete center console swap is done too. (CRX angled console, Civic Hatch is straight back and cut short)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC »</TD></TR><TR><TD CLASS="quote">If you found posts confirming the CRX Dash moving into the 4-Door with little to no modification, then that means the reverse should be true. If that's the case then you can use it in your Hatch because it's definitely known that the Hatch and CRX Dashboards are swappable without hangups providing a complete center console swap is done too. (CRX angled console, Civic Hatch is straight back and cut short)</TD></TR></TABLE>
Thank you for your help.
Dorifto13B-T
Nov 23, 2003 07:59 PM
