B16z5 engine?
posting this for a friend.
He bought a '91 CRX some time ago, and he want's to do some simple performance upgrades (bolt ons). So we checked his engine code just to be sure and it says it's a D16z5, but can't seem to find any info in the engine code.
Anyone here know anything about this engine.
We know it's a dohc non-vtec 1.6l engine.
thnx
Modified by smeck at 6:46 AM 2/21/2008
thnx
ive seen some bizarre trailing numbers on European Honda engines before but not like that.
are you sure you didnt mistake that B for a D...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa »</TD></TR><TR><TD CLASS="quote">Maybe a 88-89 Integra engine?</TD></TR></TABLE>
i dont think the b was even cast yet at that time. perhaps in prototype.
if it were 88-89 it would have to be a D-series....
i dunno OP i would suggest wiping down the area and rechecking.
another thing i would do, is pull the passenger side carpet back and read the model on the sticker of that ECU.
that will be another huge clue for you as to what you're dealing with.
I think even the earlier the 90 Integras were still B17s. I could be wrong.
Your friend also might be thinking B18C5, which would be the USDM Integra Type R motor
I think its a edm d series stamped b16z5 looks identical to the jdm dohc ZC to me...
http://www.cardomain.com/ride/316259
i honestly don't know, i just did a quick google search and found that cardomain site. dude claims he has a B16z5 in his crx, in the picture of the motor it looks like a doch zc to me... I could be wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smeck »</TD></TR><TR><TD CLASS="quote">pics: it indeed says b16z5
looks like D16Z5 to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smeck »</TD></TR><TR><TD CLASS="quote">whoops, my bad...need some more sleep....but any clue what engine this is...and the specs?</TD></TR></TABLE>same engine as JDM DOHC ZC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wikipedia.org »</TD></TR><TR><TD CLASS="quote">
D16Z5
(Basically the same engine as the D16A9, but now with a catalytic converter and lamda sensor)
* Found in:
o 1988-1992 Honda CRX (European Market)
+ Displacement : 1590 cmģ
+ Bore and Stroke : 75 mm X 90 mm
+ Compression : 9.5:1
+ Power : 124 hp (92 kW) @ 6800 rpm
+ Valvetrain : DOHC
+ Cam Gear : 34 tooth
+ Fuel Control : OBD-0 PGM-FI
+ Head Code : P7
+ Piston Code : PM7
+ ECU Code: PM7
D16Z5
* Found in:
+ Valvetrain : DOHC
+ Head Code : P7
+ Piston Code : PM7
+ ECU Code: PM7
