Problem with fuses.
Old Feb 20, 2008 | 12:08 PM
xecutor's Avatar
Default Problem with fuses.
Hey, I have a 00 civic sedan. Recently the fuse for my parking lights blew and I replaced it with an oem one and it blew right away. When I went to my local auto parts store I got another fuse however this time it was not an oem one. It does not fit flush but it is the same amperage. The fuse did not blow when I turned the parking lights on however my low beams come on with the parking lights now as well as a dim high beam indicator. When I actually turned the switch all the way for the low beams to come on the high beams came on. Then when I pulled the switch for the high beams the headlights went to low beams and the high beam indicator light lit up all the way. I decided to change the fuse to one that fit properly (oem) and when I did I noticed it blew right away. Any idea as to what I should do?
Old Feb 20, 2008 | 12:17 PM
A lil 2.3l action's Avatar
Default Re: Problem with fuses. (xecutor)
do you have any aftermarket accessories like a headunit or amp or VAFC?
Old Feb 20, 2008 | 12:20 PM
xecutor's Avatar
Default Re: Problem with fuses. (A lil 2.3l action)
No accessories at all.
Old Feb 20, 2008 | 12:25 PM
hmmm its hard to really say without looking at it... something is deff up with the wiring... what i would do is get a multimeter and check for resistance in the circuit
Old Feb 20, 2008 | 09:04 PM
NOFX's Avatar
H-T White Ops
Do you mean fuse number 32? It's a 7.5A fuse that covers the front parking lights, taillights and license plate lights.
Old Feb 20, 2008 | 11:29 PM
xecutor's Avatar
Default Re: (NOFX)
Yes, that is the fuse. All of a sudden it started working as normal, by itself.
Old Feb 21, 2008 | 04:16 AM
cachase1's Avatar
Did the car come from Canada? It almost sounds like a malfunctioning Daytime Running Lights controller to me?
Chris Chase
Exdeath
Sep 24, 2015 08:36 PM
EKcpe00
Oct 6, 2010 02:45 PM
byc_cb7
Sep 28, 2009 02:45 PM
TheTurtle
10
Nov 10, 2006 02:27 AM
built562
Nov 29, 2003 05:29 PM
