Question about my B&M short throw
Old Feb 20, 2008 | 11:29 AM
97_coupe's Avatar
Default Question about my B&M short throw
I have not checked yet to see if I can re-use mine but I had installed a B&M short throw in my 97 civic DX(stock). Now I am going to be swapping in a LS/vtec and didn't know if I could use the same short throw shifter with the 94 LS shift linkage in my DX or do I have to buy another B&M short throw for a 94 LS, thanks?
Old Feb 20, 2008 | 12:47 PM
BlueIntegraBoy's Avatar
Default Re: Question about my B&M short throw (97_coupe)
The B&M will fit the LS linkage, you'll just need to use washers to take up the extra slack in the linkage. Not too sure, you might have to swap the bottom sleeve from the B&M (d-series) and replace it with the b-series sleeve from a stock shifter.
Old Feb 20, 2008 | 01:31 PM
crazyguy's Avatar
u can reuse the shifter but u will need to reuse b&m bushing and o rings. here is the pics of mine
the black one is the oem gsr dual bend shifter.
kpjo4
Oct 3, 2009 04:29 PM
bbhockey19
Sep 24, 2006 08:21 PM
bullseye
Mar 27, 2004 10:40 PM
zigs
Jan 20, 2004 04:44 PM
youngmaeng
Mar 25, 2003 03:58 PM
