Compression Test: One Crank Hold or 4-6 Cranks ??
Old Feb 20, 2008 | 10:08 AM
MRturbo's Avatar
Default Compression Test: One Crank Hold or 4-6 Cranks ??
Well this is a long story but to make it short and simple my buddy and i were discussing which is the right way to do a compression test. Is it:
1. Crank once and hold for 4-6 seconds
or
2. Crank 4-6 times
the first time i ever did a compression test on my motor was with the one crank and hold for 4-6 seconds NOT WOT which yield 125psi on all four cyclinders. i thought this was weird because that is super low compression for a jdm gsr motor because my car ran fine. this was about five weeks ago.
yesterday i did another compression test but this time with process #2...i crank the motor 4-6 times WOT and yield 248-251 on all four cyclinders. this i thought was kind of high.
conclusion: which is the RIGHT way of doing it?
Old Feb 20, 2008 | 10:11 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Compression Test: One Crank Hold or 4-6 Cranks ?? (MRturbo)
Crank until the pressure stabilizes. Tpically 4-5 cranks will do it.
Old Feb 20, 2008 | 10:12 AM
MRturbo's Avatar
Default Re: Compression Test: One Crank Hold or 4-6 Cranks ?? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Crank until the pressure stabilizes. Tpically 4-5 cranks will do it.</TD></TR></TABLE>
what we were arguing about was is there a difference between HOLDING the crank and cranking it multiple times.
Old Feb 20, 2008 | 10:27 AM
BAYsikDC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MRturbo &raquo;</TD></TR><TR><TD CLASS="quote">
what we were arguing about was is there a difference between HOLDING the crank and cranking it multiple times.</TD></TR></TABLE>
hold it for 4-6 cranks
Old Feb 20, 2008 | 10:47 AM
Dogginator's Avatar
Daisy... Daisy...
No. The compression gauge will retain the maximum pressure. You have to release it after recording the reading.
Old Feb 20, 2008 | 06:07 PM
MRturbo's Avatar
N/M Figured it out.
Modified by MRturbo at 7:23 PM 2/20/2008
Old Feb 20, 2008 | 06:25 PM
Fern413's Avatar
First remove all your spark plugs....disable your fuel system and disable your ignition..then start at cyl number 1 and crank engine 7 times at W.O.T then youll get your reading
JDM_ITR
19
Aug 20, 2003 04:44 PM
obsidianG35
Aug 20, 2003 02:04 PM
bossman032
33
Jun 5, 2003 07:41 PM
JCracer723
Aug 21, 2002 07:50 PM
Cyber ITR
Feb 12, 2002 03:19 PM
