FS: 1999 Civic Ex: Fully Built GT35R D-Series
Old Feb 20, 2008 | 09:57 AM
Threads's Avatar
Default FS: 1999 Civic Ex: Fully Built GT35R D-Series
1999 Civic Ex: $11500 OBO
The Bad: Long Crack in front windshield, leaks oil and a bit of coolant, and 3rd gear doesnt like to go in sometimes(stock d trannys are cheap and dime a dozen). I will even be willing to include one if its that much of a problem.
This car has a/c and power steering and has about 15k miles on the motor, 110k on the chassis. I will need to recharge the A/C and the A/C is only cold while moving because when the car stops all of the heat from the mani and turbo heat soak the condenser...
If I cant sell the car whole, I will probably part her out during the summer. I also may take some things off if the price gets too low.
Number: 504-214-5757 name is Michael.
Car is located in New Orleans, LA
VIN is available on request.
or you can pm me or email me at mmisshore@gmail.com
Mods:
Exterior:
16" Gun Metal Rota Grids w/ Polished Lip
[Civic Type-R Style Rear Lip
Civic Type-R Style Front Grille
Civic Type-R Style Gun Metal Housing Headlights
Techone 6000K HID Kit
Interior:
Black w/ Blue Stitch Shift and E-Brake Boot
Spoon Shift ****
Bride Style Front Seats
Alpine Head Unit
Defi D-Gauge Boost, Oil Pressure, and EGT Gauges
Autometer 2-Gauge Instrument Cluster Pod
Autometer 1-Gauge Pod
Civic Si Guage Cluster
Apex'i AVC-R Boost Controller
Chipped P28 ECU
Neptune Engine Managment System
Boomslang OBD2b-OBD1 Conversion Harness
Under the Hood:
Garrett GT3582R .63 a/r
Spoolin Performance Stainless Steel A/C Compatible EL Streetpower Manifold(Ramhorn)
Spoolin Performance/Custom Stainless Steel 2.5" - 3" Downpipe
Spoolin Performance Dumptube
Tial Blue 38mm Wastegate
Tial Blue 50mm Blow Off Valve
Stealthmode Oil Line & Firewall Kit
Treadstone 10.5" Front Mount Intercooler
ATP Turbo Silicone Couplers and T-Bolt Clamps
Precision 780cc Injectors
Custom 2.5" Intercooler Piping
Tuner Toys Water Cool Kit
Edlebrock Performer X Intake Manifold
Professional Products 68mm Throttle Body
Golden Eagle Fuel Rail
Aeromotive Fuel Pressure Regulator
Walbro 255lph Fuel Pump
-6 AN Stainless Steel Feed and Return Lines
AEM Tru Time Cam Gear
12" Slim Fans
GM 3Bar Map Sensor
K&N 4" Air Intake Filter
Custom PCV System with KMS Fab Custom Catch Can
Prothane Motor Mounts Inserts
Kteller 3" Stainless Steel Testpipe
Kteller 3" Stainless Steel Exhaust
Megan Racing N1 Style 3" Muffler
In the Engine:
D16Y8 Block
D16Z6 Head
Golden Eagle Sleeved and Assembly
Headgames Headwork
5 Angle Valve Job
Crower Stainless Steel Valves
Crower Valve Springs
Crower Titanium Retainers
Zex 59500 Camshaft
Wiseco Pistons .020"
Pauter Rods
ARP Headstuds
Endyne Modded Honda OEM Oil Pump
Honda OEM Head Gasket
Honda OEM Gaskets
Honda OEM Bearings
Honda OEM Water Pump
Honda OEM Headgasket
Honda OEM D16Y8 Distributor and Spark Plug Wires
BKR7ES-11 Spark Plugs
Drivetrain:
Clutch Specialties Stage 2 Clutch
Lightened OEM Flywheel
Suspension:
215/45/16 Falken Azenies RT-615
Koni Red's
Eibach Pro-Kit
And a lot of Misc. Extra Stuff I will No longer Need!!!
Before Install:
Modified by Threads at 6:28 PM 2/20/2008
Modified by Threads at 5:09 PM 2/21/2008
Old Feb 20, 2008 | 12:47 PM
kabaroo's Avatar
Default Re: FS: 1999 Civic Ex: Fully Built GT35R D-Series (Threads)
sick setup... brings me back to my built d series days.
ps read my sig
Old Feb 21, 2008 | 09:19 AM
Threads's Avatar
Default Re: FS: 1999 Civic Ex: Fully Built GT35R D-Series (kabaroo)
still for sale
Old Feb 21, 2008 | 09:22 AM
bblkraz33's Avatar
luv it
Old Feb 22, 2008 | 04:50 PM
Threads's Avatar
daily bump.
Old Feb 24, 2008 | 07:44 PM
Threads's Avatar
bump
Old Feb 26, 2008 | 06:45 AM
Threads's Avatar
Still for sale taking best offers.
Old Mar 3, 2008 | 09:18 AM
Threads's Avatar
bump
Old Mar 11, 2008 | 09:17 AM
Threads's Avatar
bump, comes with stock seats now...
crxsi8
Dec 24, 2008 12:30 AM
loco_ese
Jan 11, 2006 12:16 PM
Bone Stock
Apr 12, 2004 03:58 PM
COMplex.
Feb 11, 2003 07:32 PM
