Check Engine Light
whats up H-T members, right not its like -20 below 0 with out the windchill, i was driving to work this morning and BAM... got a check engine light, went to jump the ecu, and ended up getting 4 short blinks and 3 fast blinks with the check engine light, which would be code 43... Fuel Supply System, so i reset the ECU by pulling the fuse under the hood, and went to check for codes again and the check engine light stayed solid, which is no code, could i be pulling this code because its sooo flippin cold out ? my car is a 94 Integra LS
Thanks
Thanks
type Gendy
Apr 21, 2003 04:48 PM
