went 500 miles overdue on oil change
Old Feb 19, 2008 | 11:21 PM
Del Sol on Steroids's Avatar
Default went 500 miles overdue on oil change
and, car started running sluggish, idle was horrible , and got a vtec spool code.
idle would jump when braking, and then it would go down to almost stalling then jump again.
the oil change help against the sluggisg fell, but still get horrible idle. has anyone gone through this?
also will replace solenoid gasket soon as i can
problem fixed, del sol roof leak got ecu soaked. was giving about 9:1 air/fuel
Modified by Del Sol on Steroids at 6:38 AM 2/21/2008
Old Feb 20, 2008 | 01:59 AM
VRD^sam's Avatar
Default Re: went 500 miles overdue on oil change (Del Sol on Steroids)
i've gone 1k over my oil changes in my beater and its been running fine for 2 years d16y8
Old Feb 20, 2008 | 05:07 AM
bakertime's Avatar
Yeah, that's not because you went too long on an oil change. Your engine doesn't die after 3000 miles, its just better for it to change more often. Sounds like your problems are unrelated.
Old Feb 20, 2008 | 05:17 AM
lmike6453's Avatar
well you should give us more detailed info...how many miles on the car? what kind of oil? what oil filter? what is the car used to? and also, how long in terms of months has it been?
i change mine every 3 months, where i usually drive under 2k miles
Old Feb 20, 2008 | 05:22 AM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids &raquo;</TD></TR><TR><TD CLASS="quote">and, car started running sluggish, idle was horrible , and got a vtec spool code.
also will replace solenoid gasket soon as i can</TD></TR></TABLE>
sounds like sludge to me...
Old Feb 20, 2008 | 06:01 AM
jhammond_82's Avatar
Reject Papi
Default Re: went 500 miles overdue on oil change (Techno Tonis)
wow, i bet you can even tell a difference because you didn't get your tires rotated 200 miles ago huh? give me a break. just because you didn't change it when it was scheduled to doesn't mean your car is going to fall apart. hell, when i bought my stratus it had 42,xxx on it, the sticker in the window said next oil change due 21,xxx. and it ran fine. i did change the oil, and noticed no difference. so i'm sure what ever difference you "feel" that you can notice is just your consience.
Old Feb 20, 2008 | 08:50 AM
jomama's Avatar
going 500 over on an oil change won't hurt you. running really LOW on oil will. you probably have other issues going on. GL
Old Feb 20, 2008 | 02:33 PM
MechEng's Avatar
Default Re: (jomama)
OMG thanks for the laughs.... oil lasts much longer than 3000miles. The oil companies and lube shops give that interval. I change my oil every 7000miles and my Prelude has 180,000miles.
Old Feb 21, 2008 | 02:37 AM
Default Re: (MechEng)
gotsol0326
Nov 29, 2016 12:40 PM
90Rexx
Jul 10, 2008 05:47 PM
JimmieD
Honda S2000
18
Mar 3, 2005 05:36 AM
integraboi1010
Sep 15, 2004 11:31 AM
MugenSiR
Sep 12, 2002 02:10 PM
