2005 ACURA TSX RIMS AND TIRES
<u>* * * * * 2005 ACURA TSX RIMS AND TIRES FOR SALE * * * * *</u>
I currently have my 2005 Acura TSX Rims With Tires up for sale.
This sale is for the complete set of 4 rims, mounted with 4 tires, and comes with 4 Acura centercaps. These rims and tires are mounted and balanced and are ready to be on your car...no adjustments needed.
<u>RIM SPECIFICATIONS:</u>
2005 Acura TSX, 7-spoke, stock rims
One rim has some very slight curbing, but can easily be fixed if desired.
- Diameter: 17"
- Width: 7"
- Offset: +55mm
- Bolt Battern: 5 x 114.3mm (5 x 4.5")
- Centerbore: 64.1mm
- Color: Silver
- Manufacturer: Honda Motor Co., Ltd.
<u>TIRE SPECIFICATIONS:</u>
Michelin Pilot HX MXM4 (Radial XSE) P215/50 R17 93V
For more information regarding these Michelin tires, please click here.
- Width: 215mm
- Aspect Ratio: 50
- Construction: Radial
- Inner Diameter: 17"
- Load Index: 93 (1433 lbs.)
- Speed Rating: V (Up to 149 m.p.h.)
- Miscellaneous: Black Sidewalls
- Tread Depth: 6/32"
- Treadwear: 300 rating by Michelin
- Traction: "A" rating by Michelin
- Temperature: "A" rating by Michelin
- Miscellaneous: Mud And Snow rated
<u>MISCELLANEOUS</u>
These rims have been pampered since I bought the car. Only one (1) rim has some very slight curb rash. Rims have been cleaned, waxed, and buffed and are ready to be mounted to your car. All rims are true and round, never been bent or reconditioned. Rims are already balanced with center weights. Rims also include one set of four (4) matching Acura center caps.
Tires have 23,000 miles on them, mostly highway driving. Tires/rims have been rotated every 10,000 miles. Tires are marked accordingly:
FD - Front Driver
FP - Front Passenger
RD - Rear Driver
RP - Rear Passenger
When mounted, the tires marked RD and RP should be moved to the front of the car for proper rotation.
I have used these tires in the snow. While I do not recommend that these tires be used for heavy snow conditions, they will work in light snow just fine. These tires left me stranded in a blizzard because they could not gain traction on a small hill. Again, these tires are not recommended for heavy snow use.
<u>PRICE</u>
$600.00 + shipping...firm. Rims can be picked up at an agreed upon public location if you are local within the San Diego area.
Sold as is. No money back guarantees, so please ensure that these rims will fit your car. I am not responsible for improper fitment.
Please PM for any questions you may have. Thank you.
Below are the pictures of the rims and tires that are for sale. Hopefully you will be able to see the preview image, a link to the large (1280 x 960) full image, and a description of what is being shown. If the pictures do not work for any reason, please let me know and I will find another site to rehost the images.
All 4 rims and tires.
http://www.we-todd-did-racing....s.JPG (1280 x 960)
Front Driver
http://www.we-todd-did-racing....r.JPG (1280 x 960)
Front Driver (Rear)
http://www.we-todd-did-racing....9.JPG (1280 x 960)
Front Passenger
Front Passenger (Rear)
Rear Driver
Rear Driver (Rear)
Rear Passenger
Rear Passenger Scratch
http://www.we-todd-did-racing....h.JPG (1280 x 960)
Rear Passenger Scratch (Close-Up)
Rear Passenger (Rear)
- Diameter: 17"
- Width: 7"
- Offset: +55mm
- Color: Silver
- Width: 215mm
- Aspect Ratio: 50
FD - Front Driver
RD - Rear Driver
RP - Rear Passenger
<u>PRICE</u>
Front Driver
Front Driver (Rear)
Front Passenger
Rear Driver
Rear Driver (Rear)
Rear Passenger
2005 TSX
Sep 3, 2007 07:53 PM
