for sale: b16 shortblock, ecu, d series axles (new), greddy turbo kit,
<U><FONT COLOR="red"><FONT SIZE="6">All prices are OBO</FONT></FONT></U>
<U><FONT COLOR="green"><FONT SIZE="6">WILLING TO ACCEPT TRADES!</FONT></FONT></U>
<FONT COLOR="orange"><FONT SIZE="3">Wakaba/shoshinoya badges</FONT></FONT>
<FONT COLOR="blue">i have the handicap one (blue circle with white clover) (push hanger and magnet aval.) </FONT>
<FONT COLOR="green"> wakaba badge (green/yellow split down the middle leaf) (push hanger and magnet aval.) </FONT>
<FONT COLOR="orange"> shoshinoya badge (orange/yellow tear drop deisghn) (push hanger, sticker and magnet aval.) </FONT>
<FONT COLOR="red"> all wakaba badges $5 each</FONT>
<FONT COLOR="orange"><FONT SIZE="3">greddy D series turbo kit</FONT></FONT>
<FONT COLOR="blue">cast iron log-type manifold. comes with down pipe adapter. it is smog legal if you get all of the parts included in the kit. i only have the manifold and downpipe adapter. $250</FONT>
<FONT COLOR="orange"><FONT SIZE="3">EF trailing arms</FONT></FONT>
<FONT COLOR="blue">trailing arms are the same for disc AND drum cars, you just have to swap out the brake section. i kept these as a spares but now they are just taking up space. $45 </FONT>
<FONT COLOR="orange"><FONT SIZE="3">EG trailing arms</FONT></FONT>
<FONT COLOR="blue">from my 1993 civic, nothing wrong with them just pulled out when i did the rear disc swap. again kept them as spares. $50 </FONT>
<FONT COLOR="orange"><FONT SIZE="3">B16a integra XSI block</FONT></FONT>
<FONT COLOR="blue">OBD0 JDM block, includes crank, oil pan and oil pump. </FONT>
<FONT COLOR="orange"><FONT SIZE="3">B16 OBD0 exhuast manifold</FONT></FONT>
<FONT COLOR="blue">from the same XSI, includes both O2 sensors, and heatshields and b pipe $40</FONT>
<FONT COLOR="orange"><FONT SIZE="3">EG rear drum prop valve (30/30)</FONT></FONT>
<FONT COLOR="blue">from my civic, $10</FONT>
<FONT COLOR="orange"><FONT SIZE="3">D series axles</FONT></FONT>
<FONT COLOR="blue">for 92-95 civic, new from autozone. both axles for $75 w/ castle nuts.</FONT>
<FONT COLOR="orange"><FONT SIZE="3">92-95 under hood a/c componets</FONT></FONT>
<FONT COLOR="blue">includes a/c compressor, condensor, dryer and some of the lines needed $80</FONT>
<FONT COLOR="orange"><FONT SIZE="3">P2p ECU </FONT></FONT>
<FONT COLOR="blue">96-00 d16y8 ecu, ill post a pic of the pinout/interior in a few days $75 </FONT>
<FONT COLOR="orange"><FONT SIZE="3"> EG power steering pump and lines</FONT></FONT>
<FONT COLOR="blue">for 92-95 civic, works came off of the car becuase i did a looped setup on the k series civic</FONT>
<FONT COLOR="orange"><FONT SIZE="3">faze gauge pod for a-pillar</FONT></FONT>
<FONT COLOR="blue">gauge pod screws to a-pillar, may require modification. it's black still in packaging. holds two (2) two and one-half inch gauges (2 1/2") gauges so it holds two gauges that are in 2.5 inches in diameter $35 </FONT>
<FONT COLOR="orange"><FONT SIZE="3">Knn filter</FONT></FONT>
<FONT COLOR="blue">for nissan 200sx rear wheel drive. powered by the eight-spark plugged CA20E motor </FONT>
<FONT COLOR="orange"><FONT SIZE="3">2 sony amps, cables and cap</FONT></FONT>
<FONT COLOR="blue">the 2 sony amps are a 2 channel 760W and a 4 channel 250W, the cap has an lcd screen has a dent in it and says lightening on it. cables are rockford fosgate for the amps and cap. best offer </FONT>
<FONT COLOR="orange"><FONT SIZE="3">R12-r134a conversion kit</FONT></FONT>
<FONT COLOR="blue">includes a recharger kit so you can do it yourself at home and both high and low fittings to adapt to your old system. $30 </FONT>
<FONT COLOR="orange"><FONT SIZE="3">D16a6 valve cover</FONT></FONT>
<FONT COLOR="blue">Bare aluminum valve cover, if nobody wants it ill use it to practice welding in fittings for it. </FONT>
<FONT COLOR="orange"><FONT SIZE="3">D-series 4-1 oem exhuast manifold </FONT></FONT>
<FONT COLOR="blue">off of my freinds CRX, he gave it to me back in highschool when i needed a new exhuast manifold.......$15? </FONT>
<FONT COLOR="orange"><FONT SIZE="3">blown crx si trans</FONT></FONT>
<FONT COLOR="blue">housings still good, gear teeth are sheered. use it for fabrication/mockup? $ w/e </FONT>
<U><FONT COLOR="maroon"><FONT SIZE="8">FEEL FREE TO BUMP </FONT></FONT></U>
Modified by RS2 FAB at 12:47 AM 2/20/2008
Modified by RS2 FAB at 11:29 PM 2/26/2008
Modified by RS2 FAB at 11:30 PM 2/26/2008
<FONT COLOR="gold"><FONT SIZE="6">BUMP</FONT></FONT> <FONT SIZE="6">BUMP</FONT>
<FONT SIZE="6">BUMP</FONT> <FONT COLOR="gold"><FONT SIZE="6">BUMP</FONT></FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS2 FAB »</TD></TR><TR><TD CLASS="quote"><FONT COLOR="gold"><FONT SIZE="6">BUMP</FONT></FONT> <FONT SIZE="6">BUMP</FONT>
<FONT SIZE="6">BUMP</FONT> <FONT COLOR="gold"><FONT SIZE="6">BUMP</FONT></FONT></TD></TR></TABLE>
wtb list (short version):
cheaper OEM parts:
-k series engine harness stock
-k series charging harness stock
-black 92-93 dash w/out the optional air bag (do not want the 94-95 black with the airbags or the 92-93 dashes with the air bag option installed)
-acura RDX injectors
-toyota pig tails and injector clips
-RBC top timing chain guide (its like 14.99 at the dealer but by the time school is out it's 10 pm )
-k20a2 halfshaft stock (or any k series)
-OEM 92-95 civic coupe/sedan inner taillights
-acura RSX shifter box
more expensive OEM parts:
-RBC intake manifold
-k20a2/z3 head casting
-plug and play harness for 92-95 civic EG w/ k swap
-k20 transmisson 02-04 rsx or k20a-r will accept 05-07 maybe (if its the new si trans ill take it)
aftermarket parts :
-RBC intake manifold adapter (cable throttle body)
-karcepts shifter kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PonoED »</TD></TR><TR><TD CLASS="quote">
thanks
saw this on another website im still laughing
Why do they call it the SRT-4?
Because it only turns 4 degrees and you'l hit an SRTREE
</TD></TR></TABLE>thanks
