Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
quick fog light comparison question
Old Feb 19, 2008 | 09:11 PM
Dat Fiyahhh's Avatar
Default quick fog light comparison question
about to finally order some fog lights but was wondering whats the difference between these 2 fogs from different places besides the big cost differences....this one cost 250.00 http://www.hondapartsdeals.com...ic-si from honda parts deal and the other is only 75.00 http://robearracing.com/pd_oem...i.cfm from robear racing..any help would be apperciatedd
Old Feb 19, 2008 | 09:21 PM
a1staecksauce's Avatar
From: Westminster/Huntington Beach/Seal Beach, CA, United States
Default Re: quick fog light comparison question (Dat Fiyahhh)
the one from hondapartsdeals is the actual, real, legit, OEM foglight kit. the one from the other site is OEM "style" but not the real thing.
Old Feb 19, 2008 | 09:25 PM
Default Re: quick fog light comparison question (a1staecksauce)
now would that be a big difference on quality..i might as well buy the one that last longer
Old Feb 20, 2008 | 04:48 AM
2008fijibluesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat Fiyahhh &raquo;</TD></TR><TR><TD CLASS="quote">now would that be a big difference on quality..i might as well buy the one that last longer </TD></TR></TABLE>
I would go with the Honda OEM foglight kit. For one, since it is Honda OEM, it is covered by a one year warranty (against manufacturers defect). It won't cover broken glass, but you will most likely have broken glass in any foglight you get.
Also, with the Honda OEM kit, you get everything that you need, including the zipties, that fit into factory locations, all the wiring that will clip right into your stock wiring, the relay(s), all screws, and the stock switch. The other says is has a "factory style" wiring harness. I have heard people buying the "factory style" light kits before, and they still have to splice everything in.
Old Feb 20, 2008 | 06:58 AM
misterghost's Avatar
have you seen the instructions for the fog light install?
its no easy task, since you have to have the exact harness to fit (it has a wire hanging WTF?, but it goes directly in a connector you have to disasemble )
i would highly advise against the OEM-TYPE ones....its so much of a hassle to have to take out the bumper, and trim panels on the interior to find something is wrong...
Old Feb 20, 2008 | 07:53 PM
kwh165's Avatar
If you have an 2007 Si Coupe, the OEM-style's fog light switch will not fit because the VSC traction switch has used up the location. The Honda factory kit comes with a new headlight switch with the fog light. Also, the Honda factory fog kit will have an indicator light on the dash.
Old Feb 21, 2008 | 01:53 PM
cjsansom's Avatar
Default Re: quick fog light comparison question (kwh165)
Also if you've got a NON Si 4 door, the Honda fog light kit comes with a new light control stalk that replaces the one currently on the left of your steering column. The new stalk controls your headlights, park lights, and the new fogs.
08V31-SNA-100
CS
Old Feb 21, 2008 | 03:21 PM
Default Re: quick fog light comparison question (cjsansom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjsansom &raquo;</TD></TR><TR><TD CLASS="quote">Also if you've got a NON Si 4 door, the Honda fog light kit comes with a new light control stalk that replaces the one currently on the left of your steering column. The new stalk controls your headlights, park lights, and the new fogs.
08V31-SNA-100
CS</TD></TR></TABLE>
The Honda OEM Kit does this for all 2007+ civic models. In 2006, the switch was located on the dash, but they changed it in 2007, and put the foglight switch on the headlight stalk (like you said). 2007+ models (si or non-si; coupe or sedan), will all receive the entire stalk as part of the kit.
Old Feb 22, 2008 | 07:01 AM
KlickityClack07's Avatar
Default Re: quick fog light comparison question (2008fijibluesi)
I just got some OEM foglights. If you want OEM you should look on the classified forums here or on 8thcivic.com. I got mine brand new for $180 shipped. People are always selling those on these forums.
Old Feb 23, 2008 | 12:00 AM
Diaz90's Avatar
is there a write up on how to install the foglights yet? i just got a 08 lx and gonna buy some fogs..but lookin for some DIY page for foglights
Old Feb 23, 2008 | 08:21 AM
Default Re: quick fog light comparison question (Diaz90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diaz90 &raquo;</TD></TR><TR><TD CLASS="quote">is there a write up on how to install the foglights yet? i just got a 08 lx and gonna buy some fogs..but lookin for some DIY page for foglights </TD></TR></TABLE>
http://www.8thcivic.com/forums....html
Old Feb 23, 2008 | 06:51 PM
Diaz90's Avatar
Default Re: quick fog light comparison question (KlickityClack07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KlickityClack07 &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.8thcivic.com/forums....html</TD></TR></TABLE>
good lookin out man
bobmugen
Dec 7, 2007 03:16 PM
fastcrvi
Nov 24, 2007 09:25 PM
HomeDepotMade
Jun 10, 2007 12:14 AM
Extreez
Aug 24, 2006 11:16 AM
eclipsegsx012
Honda Civic (2001 - 2005)
Jun 12, 2006 06:17 PM
