farewell to the D :( carnage pics
Old Feb 19, 2008 | 06:59 PM
THEDirtyDseriesWOOT's Avatar
Default farewell to the D :( carnage pics
well i got it in and drove it daily @ 10 psi for about 3 weeks.. and i was on the highway cruising @ 80mph and i hear a slight knock.. pull over and yep its a rod knocking away @ idle.. well im 15 miles from my town so i try to limp it back home to save on a wrecker fee.. well 1 mile from the exit... boom it lets go..
destroyed the #1 rod...
the piston looks like it made contact with the valves.. the valves are 1mm oversized ferrerra titainium.. they dont look bent they dont even look like the were touched, but the pston says otherwise.. time to build that sleeved block i have.. hopefully i will only need a rod and piston and not vavles..
see the marks by the vavle reliefs.. i hope the valves are stronger than the pistons prob not though ..
Old Feb 19, 2008 | 07:10 PM
boostismycrack's Avatar
E-thug
Default Re: (THEDirtyDseriesWOOT)
That sucks. What went wrong, bearing clearance issue?
Old Feb 19, 2008 | 07:16 PM
i really dont know.. just ost oil pressure maybe,.. somthing got clogged up who knows..
i dont think it was bearing clearance cause the bottom end was in my black civic for over a year with no probs
Old Feb 19, 2008 | 07:49 PM
dannydos's Avatar
ouch.....!
Old Feb 19, 2008 | 08:06 PM
arc_55's Avatar
Default Re: farewell to the D :( carnage pics (THEDirtyDseriesWOOT)
yeah looks as if it was a oiling issue for sure! Are there anything left of the rod bearings? Any signs to the other rod bearings or mains?
Old Feb 19, 2008 | 08:08 PM
CoreyR's Avatar
Default Re: (dannydos)
wow you destroyed that eagle rod...youre the man
Old Feb 19, 2008 | 08:17 PM
HYBRDcrx's Avatar
do you think a rod bolt came loose and caused the other to loosen?!?!?! sorry for the loss
Old Feb 19, 2008 | 08:22 PM
Archidictus's Avatar
Unceasing Measure
Default Re: farewell to the D :( carnage pics (HYBRDcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRDcrx &raquo;</TD></TR><TR><TD CLASS="quote">do you think a rod bolt came loose and caused the other to loosen?!?!?! sorry for the loss </TD></TR></TABLE>
What he thinks doesn't matter much. When he KNOWS something, we'll talk. We don't need to start baseless hypotheses floating around here simply because his D-series shat itself.
Old Feb 20, 2008 | 12:18 AM
Legion's Avatar
* B A N N E D *
Default Re: farewell to the D :( carnage pics (Archidictus)
Oh god, my worst nightmare. I probably watch my oil press. gauge more than I watch the road.
Was this on a y8 oil pump...?
Old Feb 20, 2008 | 02:08 AM
140sx's Avatar
your car is RHD is that a legit car or a conversion, hopefully the rebuild gos smooth for you.
Old Feb 20, 2008 | 04:33 AM
kdawgy2k1's Avatar
To the post above me... Thats a great eye you got... I noticed the master cyl is on the other side as well...
But back to the motor... Yeah best thing to do to see where you began to go wrong would be to look up on the oil pump and see if you have bearing material... if not then my next guess would would be a rod bolt failed... Good luck and nice set up... Ill be subscribing to your next build...
Approx how much power were you making... thats a decent sized blow dryer my friend... LOL
Old Feb 20, 2008 | 05:44 AM
Running925's Avatar
Default Re: (kdawgy2k1)
well that sux..
in for answers as to what happened.
Old Feb 20, 2008 | 05:52 AM
EK_vzla's Avatar
Default Re: (Running925)
damm eagle broke
Old Feb 20, 2008 | 08:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kdawgy2k1 &raquo;</TD></TR><TR><TD CLASS="quote">To the post above me... Thats a great eye you got... I noticed the master cyl is on the other side as well...
Approx how much power were you making... thats a decent sized blow dryer my friend... LOL </TD></TR></TABLE>
prob only making 300whp when it broke..
i was on low boost..
motor is year old.. been through hell.. havent even checked the other bearings but i iwll tonight.. it looks like a arp bolt just took a dump..
the bolts are arp2000 bolts the big ones
Old Feb 20, 2008 | 09:31 AM
HiProfile's Avatar
Wow, sucks to ruin eagles and ferra valves.
I have one question though, why did you notch the girdle? My eagles clear the z6 girdle just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old Feb 20, 2008 | 10:53 AM
69NOSAJ's Avatar
Damn Dirty! That blows
good luck w/ the rebuild
Old Feb 20, 2008 | 12:31 PM
Default Re: (HiProfile)
it got really close to my girdle i didnt wanna take a chance.. so i notched to be safe
Old Feb 20, 2008 | 12:35 PM
.PLUMMM's Avatar
Time to come back stronger and boost more on that freshly built block! Sorry about the loss though. You ever find out if it was Oil Press. or not? Great pics of the damage too
Old Feb 20, 2008 | 02:05 PM
quicksilver1689's Avatar
i ♥ snails
damn that sucks man ive been following your build for awaile. Rod looks like it got pretty damn hot .
Old Feb 20, 2008 | 02:32 PM
Unsivil_audio's Avatar
Next time stop driving it. You'll save yourself some money. Probably could have got away with a bearing change (just dropping the oil pan).
Old Feb 20, 2008 | 02:41 PM
SOHC_MShue's Avatar
Holy **** that rod is messed up. Sorry about your shitty luck man
Old Feb 20, 2008 | 04:30 PM
Newt Dog's Avatar
Default Re: farewell to the D :( carnage pics (SOHC_MShue)
Good posibility you spun a bearing! That sucks dirty! Exspecialy this close to race season!!
Old Feb 20, 2008 | 05:32 PM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Wow, sucks to ruin eagles and ferra valves.
i had to notch my z6 girdle because the rod bolts hit it. i dont know it some of the girdles are different or if i just had different rod bolts, the bolt head on them was really big but they were the ARP 2000's
Old Feb 20, 2008 | 05:51 PM
EK_vzla's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">Rod looks like it got pretty damn hot . </TD></TR></TABLE>
x2
