Chipped p28 or JDM p13
Old Feb 19, 2008 | 06:54 PM
H22_aCCoRd_07's Avatar
Default Chipped p28 or JDM p13
Like the title says?????
Info:
94 Accord lx
Stock Jdm H22 with minor mods
Header
intake
Type s intake mani
Type s TB
Greddy Sp2 exhaust
Old Feb 19, 2008 | 07:01 PM
98vtec's Avatar
moderator emeritus
Default Re: Chipped p28 or JDM p13 (H22_aCCoRd_07)
are you going to tune it or not?
if not, p13.
Old Feb 19, 2008 | 07:11 PM
Default Re: Chipped p28 or JDM p13 (98vtec)
i was planning on using one of the ebay skunk 2 chips.
Vtec: where ever i want
redline: 8200
2 step: 4500
Old Feb 19, 2008 | 07:13 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22_aCCoRd_07 &raquo;</TD></TR><TR><TD CLASS="quote">i was planning on using one of the ebay skunk 2 chips.
redline: 8200
2 step: 4500
go with the p13.
Old Feb 19, 2008 | 07:18 PM
well the reason i dont wanna go with the p13 is that im getting a really wierd rev problem. Its hard to explain but when im in nuetral my rpm's shoot up to like 3,000 or even 5 sometimes. but it doesnt do it when my car is completely stopped.
Oh and i dont have any cel.
and with a stock p28 my car runs like normal
Old Feb 19, 2008 | 07:21 PM
98vtec's Avatar
moderator emeritus
so you think some ebay chip, with god knows what is on it, is going to magically make the car run better?
ECU tuning does not work like that.
Either buy the ecu that was made for the car or buy a p28 and have it TUNED properly.
Old Feb 19, 2008 | 07:37 PM
well i know that... i was just saying when i put a STOCK p28 in my car it runs perfectly and thats why i prefer using a P28 then chipping it to make it rev a little higher, make vtec kick in a little earlier, and have fun with 2 step
Modified by H22_aCCoRd_07 at 12:41 PM 2/20/2008
Old Feb 20, 2008 | 06:27 AM
mattsnooz's Avatar
He's not saying you can't put a P28 with a ebay sh*t chip in it. In a way though your trying to fix your car by stuffing a piece of sh*t into the ecu.
You do it your way, your car may work right for a bit but it could blow ANY time.
If you get a P28 with decent tuning software, and have it professionally tuned, your car will run WAY better, and will likely* have a longer life. (in simple terms)
You could cheap out and socket your p28, and chip it with a premade h22 base-map though. That would probably be safer than an ebay chip (jun, mugen, etc)
If you get a base-map though make sure its off some one reputable. There are lots of good guys here on H-T that should have a good h22 base-map for you.
But to maximize your mild build I'd still do as 98vtec depicts suggests. His advice is solid! Remember your car is an expensive car so to cheap out in something as important as its engine management is ludicrous.
Old Feb 20, 2008 | 09:46 AM
Default Re: Chipped p28 or JDM p13 (Apex1972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 &raquo;</TD></TR><TR><TD CLASS="quote">thanks to hard headed guys like this, there will be no more good H22s left. They will all be blown to ****</TD></TR></TABLE>
Thanks for the input by the way. Its SO well appreciated!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">He's not saying you can't put a P28 with a ebay sh*t chip in it. In a way though your trying to fix your car by stuffing a piece of sh*t into the ecu.
But to maximize your mild build I'd still do as 98vtec depicts suggests. His advice is solid! Remember your car is an expensive car so to cheap out in something as important as its engine management is ludicrous.</TD></TR></TABLE>
I never thought of it like that... thanks man
H22_aCCoRd_07
Feb 21, 2008 09:48 AM
civic0104
Aug 27, 2005 04:35 PM
Mr Instigate
Nov 2, 2004 07:17 AM
WeeMan
Aug 30, 2003 05:06 PM
