anyone know if the LX brake cylinder is 13/16ths or 15/16ths?
depends on if it had abs or not. if it had abs, then it should already have the 1'' if not it should be smaller. by the way, which cylinder are we talking about, master or wheel. i'm assuming you mean the master, since you have switched to disc in the back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steerh67 »</TD></TR><TR><TD CLASS="quote">depends on if it had abs or not. if it had abs, then it should already have the 1'' if not it should be smaller. by the way, which cylinder are we talking about, master or wheel. i'm assuming you mean the master, since you have switched to disc in the back. </TD></TR></TABLE>
whoops.. yeah i meant master.
the one inch is stock on the EX's, i can't make out what it says on my LX w/o abs. I *think* its 13/16ths, in which case the 1 inch should make a difference. but if its 15/16ths then its not worth it.
crazyhouse2011
Nov 13, 2014 02:22 PM
949
Suspension & Brakes
Aug 17, 2012 06:45 AM
spooncivic1
May 3, 2006 09:38 PM
