My car won't start
I posted a similar topic a few days ago, but I have the problem diagnosed, but don't know how to fix it.
The fuel injectors arent passing the fuel to the engine due to a safety shutoff from some sensor or something.
How.... do I locate the sensor to replace it, or... bypass the sensor to get my car running again.
Because nothing is wrong, the oil has been changed, clean 93 octane gas, half a tank, fuel pump is working and all.
The only thing not working is the fuel injectors, and they were working fine so they arent dirty, just shutoff.
I need help... it's probably something simple. Anyone know much about car electrical systems that has had a similar problem?
Thanks for any help in advance
Really don't want to have to pay a towing fee and for a mechanic if I don't have to, because I have a feeling it's something ridiculously simple.
hmmmmmm. if you cant get it fixed im in austin and would be glad to help. how do you know the injectors arent working??? noid light??? random dude blowing smoke up your ***??
They're no safety sensors for the injectors, they're either working or not. Use a noid light or other way of checking. Listen to see if your pumps priming if you think its fuel related. Go down the tree first though, air/fuel/spark.
Prolly fuel pump!!!! just go to the junk yard and get one off the same kind of car and take ur back seats off and replace the fuel pump!! Secondly does ur car even turn over?? Starter??
