gas problem car wont start help!
ok so i have a 95 integra. the car was runing fine until it just wouldnt start.i realize the car wasnt geting gas.i check the main-relay thats wasnt the problem.i check all the grounds everything seems fine.it starts with "starter fluid", i switch fuel pumps with my friends and it still wont start.and i also check ALL the fuses everything work. car cranks...any ideas?? help!!
check the fuel pump 4 spliced wires. most fuel kill switches splice directly from the fuel pump. but i had the same problem. it turned out to be the fuel filter. the filter had alot of carbon bulid up. just start tearing down the fuel system. also check 4 leeks. process of elimation is the best way to fix any problem
obviously its not a kill switch problem cause you said that you checked for fuel at the rail right? i had this same thing happen to me a couple days ago on a da. it was getting fuel at the rail and i checked for spark at all cylinders and it looked good so i was stumped as well. long story short i pulled off the dizzy cap and found that the little screw that holds the rotor on had broken off and was just spinning freely. replaced the dizzy and problem solved, good luck.(note: even though the car had spark it wasnt sparking at the right time and that could be whats happening in your case)
^^^^ ok but when i check for gas at the rail it was DRY!!!! I MEAN NO SIGNS OF GAS AT ALL!! SO I KNOW I HAVE TO SOLVE THAT PROBLEM BEFORE ANYTHING THAX FOR THE IDEA KEEP IT COMING!!
......and no i didnt check because the wires are brand new
