timing belt broke, need some help
I have a 91 Accord 5 spd that I am trying to replace the timing belt , balance belt and water pump. I have taken just about everything loose and was going to find TDC . As I started turning the crank shaft, I noticed that the distributor was not turning at all. I can use a wrench and turn the camshaft and point the rotor to #1 spark plug wire, and I can line up 0 on timing pointer. Am I missing something?
Check out the Tbelt replacement thread made by TouringAccord.
The motors are practically the same and that is a step by step guide on doing it. Hopefully that helps.
Also keep in mind that motor is an interference engine, and has a greater risk of bending stuff in the event of a tbelt snapping.
peiceofshitaccord
Nov 22, 2006 04:05 AM
