LS VTEC MOTOR CHEAPPP $600 Don't buy a B20!!
<U>SOLD!!!</U>
I have an LS bottom end for sale. B16 P30 Pistons on LS rods. B16 oil pump and water pump. Block was hot tanked and cylinders were honed prior to installing used P30 pistons and rings. The heads of the P30 pistons were bead blasted prior to install. Ring gaps are perfect and were checked before installing pistons. This motor has zero miles since it was assembled. $600 Come and get it!!! All the machine work and assembly is done for you. This motor will have 12.2:1 compression with a B16 head and it will have 12.5:1 compression with a GSR head. This will make way more power with a vtec head than a stock B20 motor and it has the proper oil pump and water pump already installed for a vtec motor.
Modified by Tomdata at 5:52 PM 2/20/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR II »</TD></TR><TR><TD CLASS="quote">"This will make way more power with a vtec head than a stock B20 motor" no **** its a built motor versus a stock motor ...expletiveing idiot
sick90hatch
18
Nov 18, 2008 01:19 PM
Irishweird00
52
Jun 3, 2003 01:06 PM
