<-- n00b, PLease Help, 4 x 114.3
ok so ima be getting the 96 spec itr conversion 114.3 and i need new rotors... does anyone know where i can get some... please let me know... thanks,...
Since its JDM and no auto part store will have it. Only thing to do is get GSR Rotor and re-drill them to 4-114.3 and slap them on. But someone correct me if i'm wrong... The ITR 4-114.3 set up has a bigger rotor than the gsr?
You could do the 282mm front brake swap (same size as USDM ITR) and use 92-96 Prelude VTEC rotors for the front. You will need to check the hub center diameter, as the Prelude rotors have a 64mm bore. I'm not sure about a swap for the rears.
https://honda-tech.com/zerothread?id=734560
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MopdiT »</TD></TR><TR><TD CLASS="quote">eBay have plenty of different kinds of rotors for your conversion....!</TD></TR></TABLE>
there u go bro
there u go bro
horsekiller
Suspension & Brakes
May 15, 2009 09:56 AM
