4-1 b-series headers not fitting ...
i have a b16a in s 91 hatch and i bought 4-1 headers and they are not clearing the bottom support bar. they look like they will if i cut the beam a little , but will that efftect the car?
Common problem. If all you need is a bit of clearance, then you can hit the cross memeber with a hammer and make room for the header. As long as all you need is a bit of clearance it will be OK. If you need 1 or more inches to make it fit, you need an aftermarket cross member or another header that fits.
Some people cut a section off the front crossmember to save money. The right way is to get an aftermarket crossmember or traction bar.
But the choice is yours
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxbore.com »</TD></TR><TR><TD CLASS="quote">Common problem. If all you need is a bit of clearance, then you can hit the cross memeber with a hammer and make room for the header. As long as all you need is a bit of clearance it will be OK. If you need 1 or more inches to make it fit, you need an aftermarket cross member or another header that fits.</TD></TR></TABLE>
He knows his stuff
He knows his stuff
just get the traction bar... knock 3 birds with one stone!
*4-1 power!!!
*better traction/launches
*reduced weight...
VIOLA!!!
*4-1 power!!!
*reduced weight...
VIOLA!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnez »</TD></TR><TR><TD CLASS="quote">
VIOLA!!!
VIOLA!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-siRII »</TD></TR><TR><TD CLASS="quote">well i did this to my civic EE9 and its drives and look like OEM
went a tad bit over board did ya??
all you have to cut off is the small lip on the crossmember, then just hammer it if you need more room, i managed to hammer mine in about an inch and that cross member is plenty beefy, it'l hold up just fine as long as you dont cut a chunk out of it.
</TD></TR></TABLE>went a tad bit over board did ya??
well belive me, that header was way to big for that little space...so i had to cut a piece out of it (otherwise i had to wait for 2 month till i got a decent traction bar, we don`t get parts as easy as you some times)...but don`t worry i reinforced the mid section of it and then weld it together...so i killed 2 birds with 1 shot
1 made the OEM cross-member lighter
2 made a really big 4-1 header fit my engine ( 4-1 power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY »</TD></TR><TR><TD CLASS="quote">
haha... pardon my french. vOIla.
...but you know im right
</TD></TR></TABLE>haha... pardon my french. vOIla.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-siRII »</TD></TR><TR><TD CLASS="quote">i know bro, but like i said...i had to wait for like 3 long mounths if i didn`t do that..
my fault homie... that post was intended for the IT GUY.
</TD></TR></TABLE>my fault homie... that post was intended for the IT GUY.
From: "That one guy with that one car" Kennewick WA
order it now, you have something decent to hold you off for 3 months. i just put on my traction bar and it completely got rid of my wheel hop
best 300 dollars ive spent this year so far.
</TD></TR></TABLE>order it now, you have something decent to hold you off for 3 months. i just put on my traction bar and it completely got rid of my wheel hop
Civictech97
17
Dec 9, 2008 03:40 PM
