B-series swap and keep the a/c
Apparently, a few people have managed to mount the Sanden compressor on a B16A compressor bracket using two or three of the bolts. There is, however, one problem: the crossmember is in the way. This, of course, could be dealt with by using an aftermarket crossmember such as the one from Innovative (it would also give you clearance for ANY header you want. BUT, the crossmember also costs around $200 (or so). So it s a toss-up money-wise. Regardless, you should probably just buy the bracket. Maybe you could find one used somewhere.
http://robearracing.com/pd_inn...1.cfm
this is the cheaper one theres another one out there out of billet aluminum thats like 190 bucks ill find the link to that
Mr. Dabolina
Jan 18, 2014 08:06 PM
tacorunner87
33
May 13, 2008 09:52 PM
