Skunk2 pro-series manifold on gsr obd2
i was just wondering if the s2 manifold pro-series would fit on the gsr without modifications, i knoe it'll fit, but what about the hoses and stuff. is it gonna be a lil bit different. i have a 99 gsr in my 94 civic si hatchback. the engine harness is obd2. everything on the motor is obd2. thanks.
its a direct bolt on once u get s2 im for gsr model. all the hoses are at the same/similar location. but u might need a new tb gasket and im gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki »</TD></TR><TR><TD CLASS="quote">kewl, but seems to me like there are some different items like the throttle body, it has some hose plugs that the obd2 throttle body doesn't have?</TD></TR></TABLE>
the hoses under oem throttle body is for cooling purpose and u can reuse the oem throttle body and plug those hoses back to manifold and other same places. or u can get a aftermarket throttle body such as skunk2, it will eliminates the cooling devise so u wont have any hoses to connect to.
well actually mine's obd2 so my throttle body doesn't have any hoses under my throttle body like the obd1 does, and the skunk2 manifold has 2 hoses to plug for the cooling purposes, on the other hand, the obd2 has only one. if i bypass it, would the ref'd station be a bitch about it.
integrasi
Aug 28, 2003 10:35 PM
