right parts for my build
i am building my motor h22 and i am trying to get 260 n/a is this possible with these parts and are they to expensive
mahle gold series 457
exeedy clutch kit and fly wheel 225
arp studs head 169
hondata head gasket 50
skunk 2 intake mainfold and throttle body 500
acl bearings 119
arm press reg w guage 187
blox cam gears 128
fuel pump 55
crowler cams 325 or obx
tuning 425
maching work don't yet
anyone got suggestions on things to change or maybe prices are to high
thanks for the help
arp studs head 169
acl bearings 119
blox cam gears 128
fuel pump 55
tuning 425
thanks for the help
260 is a pretty tough goal to hit, you will probably want to get some new rods while you're in there swapping out parts especially if you h22 is 93-96 because those engines use the pressed in wrist pins rather than the full-floating pins on the 97+ motors. Also I believe the honadata gasket you are talking about is actually an intake manifold gasket. With such an amibitious goal may consider buying all the internal components you need first so that you can buy the parts you'll need to make that power someday. I would suggest Pistons, rods, cams, and a new valvetrain, along with some tuning for starters. Also boring and honing you block normally runs ~$100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazes »</TD></TR><TR><TD CLASS="quote">i am building my motor h22 and i am trying to get 260 n/a is this possible with these parts and are they to expensive
arp studs head 169
acl bearings 119
blox cam gears 128
fuel pump 55
tuning 425
thanks for the help</TD></TR></TABLE>
1. no such thing as crowler cams. OBX....i can only hope you arent serious.
2. wheres your valvetrain?
3. where's your tools to put this together? blueprinting?
4. head work?
5. block work?
6. header?
7. exhaust?
8. hondata doesnt make a headgasket
9. read the faq.
10. you have a lot of research to do.
arp studs head 169
acl bearings 119
blox cam gears 128
fuel pump 55
tuning 425
4. head work?
5. block work?
6. header?
7. exhaust?
9. read the faq.
angela_itr
May 21, 2005 01:51 PM
