Need caliper bracket!
Old Feb 18, 2008 | 09:20 PM
EJ8 GSR-T's Avatar
Default Need caliper bracket!
Anyone have or know how to get the brackets to mate ITR calipers to a 98 civic ex?
Old Feb 20, 2008 | 08:34 AM
EJ8 GSR-T's Avatar
Default Re: Need caliper bracket! (EJ8 GSR-T)
bump
Old Feb 20, 2008 | 09:07 AM
EL Vap133's Avatar
Contact HT member "Brake Expert".
Old Feb 24, 2008 | 08:48 PM
roastbeefrichie's Avatar
Default Re: Need caliper bracket! (EL Vap133)
to install the itr calipers (stamped 17cl15vn) on your 98 civic ex, you'll need will need to be send the brackets (stamped 23T or 25T) to a machine shop, where 2-3mm or 1/8" must be milled off (where the bracket mates with the knuckle). on this set-up, you'll need an 11" rotor from a prelude re-drilled to 4X100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Contact HT member "Brake Expert". </TD></TR></TABLE>
pm brakeexpert, he machines brackets, re-drills rotors & specializes in oem honda brake upgrades
https://honda-tech.com/zerothread?id=1811368
VTecLude1994
May 13, 2011 08:11 AM
Street Racer X
Apr 24, 2011 11:46 AM
Jonathan_ED3
18
Mar 7, 2005 08:45 PM
Understeer
Dec 15, 2003 10:26 PM
