distributor makes noise?
Old Feb 18, 2008 | 08:11 PM
jdm_crx91's Avatar
Default distributor makes noise?
on my B18C motor, my dizzy makes clicking noise quite loud, is this normal? I already changed new dizzy cap, spark plugs, and NGK blue wires...does the click noise have to do anything with the way the dizzy is adjusted as well (you know, the 3 bolts holding the dizzy on the cam/motor) Also, my CEL keeps popin up saying #1 and 2 piston misfire???? HELP ANYONE...
Old Feb 18, 2008 | 08:18 PM
Echo7847's Avatar
Default Re: distributor makes noise? (jdm_crx91)
Check timing belt tension.
If thats good then most likely the bearing went bye bye and its time to buy a new sub-assembly.
Old Feb 18, 2008 | 08:49 PM
jdm_crx91's Avatar
Default Re: distributor makes noise? (Echo7847)
how do I make timing belt tension tighter? need this fixed quick...because I just barely re-did timing belt....also when pressing the belt between the cams gears, theres about 1 inch gap, is this too loose or enough tension?
Modified by jdm_crx91 at 1:16 AM 2/19/2008
ZurEnArrh
Jan 11, 2018 11:07 AM
wdraughn
Honda Civic (2001 - 2005)
Dec 1, 2010 06:16 AM
dannyboief9
Feb 21, 2010 07:23 PM
D-meet07
Sep 13, 2005 09:23 AM
