Suspension & Brakes Theory, alignment, spring rates....
Eg vs EK suspesion Can you swap them?
Old Feb 18, 2008 | 04:31 PM
Vi3tsi06's Avatar
Default Eg vs EK suspesion Can you swap them?
This has been bugging me and me bring new to the game i'm curious. are they interchangeable with each other. i see that they can in some products. i'm just curious
Old Feb 18, 2008 | 05:02 PM
PIC Performance's Avatar
Default Re: Eg vs EK suspesion Can you swap them? (Vi3tsi06)
Not all the parts. Front lower control arms, front upper control arms, rear lower control arms are different. Due to the rear lower control arms being different, EK rear shocks do not mount correctly on EG rear lower control arms, and EG rear shocks do not mount correctly on EK rear lower control arms. They require some minor modifications to work.
Old Feb 18, 2008 | 07:30 PM
redex04's Avatar
Default Re: Eg vs EK suspesion Can you swap them? (PIC Performance)
what kind of modifications?
Old Feb 19, 2008 | 04:51 AM
Vi3tsi06's Avatar
are the mods safe for riding on?
Old Feb 19, 2008 | 10:02 AM
Default Re: Eg vs EK suspesion Can you swap them? (redex04)
Well shock bushing on on the EG rear LCA is longer than the one on the EK. So to fit EK rear shocks on an EG's LCA's you grind the bushing, and to fit EG rear shocks on an EK lca you add washers. I see no reason why either one would be unsafe to drive on if done if correctly.
Old Feb 19, 2008 | 11:03 AM
hatch is best's Avatar
So if I get the eg or dc lca and shock (rear), what needs to be done for this to fit an ek?
Old Feb 19, 2008 | 11:33 AM
redex04's Avatar
Default Re: Eg vs EK suspesion Can you swap them? (hatch is best)
I believe you can make the shock/strut fit but you need to run the right LCA for your car.
Old Feb 19, 2008 | 11:37 AM
and what is the right LCA?
Old Feb 20, 2008 | 10:16 PM
chairwitharmrests's Avatar
if you have an eg then an eg or 94-01 teg lca is the right one and if its a ek then the ek lca is what you need.
I have a ?, if on an eg/dc you use an ek rear lca on the eg/dc shocks then you will just need to add washers?, or will the ek rear lca not work at all on an eg/dc?
Old Feb 21, 2008 | 05:14 PM
redex04's Avatar
Default Re: (chairwitharmrests)
eg and ek rear lca's are completly different and not interchangable
Old Feb 23, 2008 | 12:40 PM
user 98292739's Avatar
Default Re: (redex04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redex04 &raquo;</TD></TR><TR><TD CLASS="quote">eg and ek rear lca's are completly different and not interchangable</TD></TR></TABLE>
i do run CRX D2 coilovers on my EK. 6 washer on each rear shock to make it fit
Old Mar 19, 2008 | 11:52 AM
jbecke2's Avatar
Default Re: (The Lobster)
Is it possible to put an EK bushing into an EG LCA...it looks like they're the same diameter...anyone done this?
Old Mar 20, 2008 | 05:59 PM
blaak-crx's Avatar
Default Re: (jbecke2)
How about just the coils (H&R , Neuspeed...)? EG on EK? I was told that it will bring the front down alot but if I had Koni Yellows, I can bring the clip one slot higher and it will bring the car at the right level. Is it true?
Modified by blaak-crx at 9:36 PM 3/20/2008
Old Nov 25, 2008 | 02:00 PM
gabebauman's Avatar
I'll be doing this soon with my old suspension from my 98 Civic coupe to my 93 Civic hatch. What is the best method used to grind down the bushing?
Old Nov 27, 2008 | 10:29 AM
CRX T-Si's Avatar
What PIC Performance said is parctially correct.
Inorder to get EG shocks to fit into an EK the fronts work without any problem as they are the same.
The rear shocks however are different on how it mounts on the EK. EG arm bushings are longer which is true, but the distance from the top of the arm to the middle of the bushing is also shorter since the arms are cast.
EK arms on the other hand are pressed steel, first difference is the shorter shock mount bushing and yes you can add washers to make it work. However one thing that no one bothered to mention is that when you mount the EG shock onto the EK arm you will find that in order to make it you have to jack up the arm because the bottom portion on the EG shock is shorter which binds with the EK arm.
Does it work of cause but if you jack up the car the shock will hit the arm acting as a limitter which can be a bad thing or good depending on the situations.
How I know because I am using it on my EK, I cut part of the shock mount off to allow for a bit more travel. It works but thought you should know.
And to make EK shocks to fit the EG I would not suggest grinding the bushing as this creates trememdous heat which will damage the rubber part of the bushing. You can widen it by taking the 32mm axle nut and hammering it wider then compress it to fit the bushing which would also work. Did this on my CRX before, good luck. You might blow out your shock if you slam your car since the EK shock is a bit taller.
Old Nov 29, 2008 | 06:56 AM
blackedoutwk's Avatar
yea all i had to do with my eg civic is grind down the bushing in the rear to fit my ek suspension on it and i drove it with no problems for 2 years before i sold it
Old Dec 7, 2008 | 01:59 PM
rudebwoy's Avatar
I am going through a similar process.
I owned a 1995 civic coupe with integra rear disc brake conversion.
I just recently bought a German spec 99EK hatch the equivalent of the DX.
I planned to swap everything over from my EJ1 coupe to my EK hatch to include everything from engine to brakes to suspension.
I also have megan racing rear lower control arms and SRR rear sway bar.
I planned to transfer the complete trailing arm assembly to include Ksport coilovers, megan control arms, srr sway bars all together to the EK .
since I am transfering everything together with they work?
the EK also have ABS what are my solution.
Old Dec 31, 2008 | 10:59 AM
gabebauman's Avatar
Just did this to my 93 Hatch last night. Cut the shock fork bushing down and the rear shocks fit perfect. Ride is superb...just like when the shocks were on my 98 Coupe.
Old Dec 31, 2008 | 12:50 PM
Civichatch2k's Avatar
gabe,
the car looks insane!
Good work man!
Old Dec 31, 2008 | 01:07 PM
2000 hb's Avatar
Icon2 Re: Eg vs EK suspesion Can you swap them?
what about rear disc brakes.can i put ek 99-00 si rear disc on ej 92-95 hb with the ebrake cables.i know the lca are not the same but can i put the ej lca on the ek rear disc to make it work.
Old Dec 31, 2008 | 01:16 PM
gabebauman's Avatar
Yes...99-00 Si rear trailing arms will work with the 92-95 Civic chassis. You will simply reuse your 5th gen lca's with the rear disc. 6th gen lca's are not the same length.
Old Dec 31, 2008 | 03:47 PM
2000 hb's Avatar
thanks for the info.
Old Jan 3, 2009 | 09:30 PM
stmotorsports's Avatar
so eg/ek/dc trailing arms are all interchangeable? any mods needed?
Old Jan 3, 2009 | 10:01 PM
gabebauman's Avatar
Yes...they swap out directly.
Old Jun 2, 2009 | 05:52 PM
91Si_IN's Avatar
Got a newbie question...I know its an old thread but hopefully I can get an answer. I just picked up a rear setup from a 95 EX today at a junkyard. I am planning on putting them on my 96 HX. I know about the LCR thing from reading above but my car doesn't have ABS so will that be a problem at all? The 95 EX did. Also will I need to change the valve?
