ZC SWAP HELP!!!????
Old Feb 18, 2008 | 04:27 PM
liloldchevyvan's Avatar
Default ZC SWAP HELP!!!????
HELLO IM WORKING ON A ZC SWAP ON MY 91 CRX SI AND I CANT GET IT TO START. IT WILL START FOR ABOUT 4 SECONDS WHEN I SPRAY THE THROTTLE BODY WITH CARB CLEANER BUT IT JUST DIES OFF! IM RUNNING A PM6 ECU I HAVE THE SI HARNESS HOOKED UP. IM LOST ANY IDEAS??
Old Feb 18, 2008 | 04:35 PM
EF9SIRJeff's Avatar
Default Re: ZC SWAP HELP!!!???? (liloldchevyvan)
Check your grounds first make sure their all grounded properly
next it seems your not getting fuel but you can double check by listening for your fuel pump when you turn your key on
if your fuel pump turns on check to see that fuel is getting to the fuel rail (loosen the supply line slightly it will drip if you are getting fuel)
if your not getting fuel still and have good grounds check your fuel pump relay see if your can hear it click when you turn your key on
chances are bad ground or bad relay or bad pump
Old Feb 18, 2008 | 04:38 PM
Default Re: ZC SWAP HELP!!!???? (EF9SIRJeff)
I HAVE A GOOD FUEL PUMP I CAN HEAR IT RUNNING AND I HAD A LEAK IN MY FUEL FILTER LINE SO I KNOW THAT IM GETTING FUEL.
Old Feb 18, 2008 | 05:15 PM
trevino04's Avatar
i got the same problem with mine...when you find out let me know
EF9SIRJeff's Avatar
if you are leaking at the fuel filter it may be clogged check to see if your getting fuel at the fuel rail
also what ecu are you running
also turn your caps lock off
Old Feb 18, 2008 | 05:19 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liloldchevyvan &raquo;</TD></TR><TR><TD CLASS="quote">HELLO IM WORKING ON A ZC SWAP ON MY 91 CRX SI AND I CANT GET IT TO START. IT WILL START FOR ABOUT 4 SECONDS WHEN I SPRAY THE THROTTLE BODY WITH CARB CLEANER BUT IT JUST DIES OFF! IM RUNNING A PM6 ECU I HAVE THE SI HARNESS HOOKED UP. IM LOST ANY IDEAS??</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liloldchevyvan &raquo;</TD></TR><TR><TD CLASS="quote">I HAVE A GOOD FUEL PUMP I CAN HEAR IT RUNNING AND I HAD A LEAK IN MY FUEL FILTER LINE SO I KNOW THAT IM GETTING FUEL.</TD></TR></TABLE>
If you are getting fuel, but it only runs when you spray into the manifold, then you still deffinately have a fuel problem.
AND STOP YELLING, IT WILL ONLY GET YOU FLAMED
Old Feb 18, 2008 | 05:48 PM
Default Re: ZC SWAP HELP!!!???? (SIred91)
okay i have fuel goin to my rails, i know this because i had fuel spraying all over the place i replaced the orings. my injectors have 12 volts of powering going to them. im still lost......
Old Feb 18, 2008 | 06:58 PM
90efhatch's Avatar
I had no problems like that when I did my ZC swap. It still sounds like you have a fuel issue if you can spray carb cleaner in and the engine fires. You need to make sure you are getting an injector pulse. Has this computer been tested before or has it been modified? Check the timing belt also to make sure that its in time.
billy_thekid
Jan 5, 2008 06:04 AM
blinger
Sep 1, 2007 10:35 PM
crazygerman
Mar 4, 2006 11:57 AM
ek_slut
Sep 23, 2005 02:00 PM
terminaloverlowd
Jun 19, 2004 07:01 PM
