what kind of turbo is this
Old Feb 18, 2008 | 04:15 PM
hbcrazy88's Avatar
Default what kind of turbo is this
i got this whole setup when i purchased my hatch.he said it was a t4 turbo but didnt tell me the brand. the wastgate, manifold and dump tube are all turbonetics parts. to me this looks like a turbonetics style turbo also. i dont know the a/r because theres a hole with looks like a vaccume style nipple drilled into the marking. im probibly going to take it aport and measure the compresser wheels inducer and exducer tonight o find the a/r but if anyone could give me a hint on what kind this is it would be awsome.
Old Feb 18, 2008 | 04:36 PM
melovesboost's Avatar
definately a turbonetics turbo.. size i have no clue.
Old Feb 18, 2008 | 04:54 PM
hbcrazy88's Avatar
Default Re: (melovesboost)
how did you tell exactly?
Old Feb 18, 2008 | 05:02 PM
TheShodan's Avatar
Moderator
Default Re: (hbcrazy88)
Looks to be a Turbonetics 60-1 w/ larger compressor housing. because there is no picture of the turbine side directly, I don't know which exhaust whee it is using. Either way, it looks as though the compressor wheel injgested some FOD, as the inlet blade tips look a bit "rough". I'd be weary of it, and investigate further.
Old Feb 19, 2008 | 02:29 PM
hbcrazy88's Avatar
Default Re: (TheShodan)
ok i just got down taking it apart and its defently a 56 trim turbo. there is less than a millimeter of shaft play, i dont know if there are certine specs that you are supost to stay in but there is vary little. and there is one blade that has a little indent in it but not bad at all. so im planing on ordering my oil lines and then she will be on my b20vtec hatch.
Old Feb 19, 2008 | 03:15 PM
kdawgy2k1's Avatar
Yeah I'd def put my vote in for a Turbonetics Blow Dryer...
hoya_10fintec
Jul 25, 2007 10:04 AM
AZSupraT
Apr 13, 2006 05:35 AM
rusteds2k
May 11, 2005 03:02 PM
kell211
Mar 4, 2004 02:16 PM
Ri5e
May 7, 2002 05:23 PM
