where to get poly urethane radius rod bushings???
Old Feb 18, 2008 | 04:05 PM
crooked muffler's Avatar
Default where to get poly urethane radius rod bushings???
where to get poly urethane radius rod bushings for EF chassis???
I need to cure my wheel hop...
someone link me
Old Feb 18, 2008 | 04:12 PM
EF9SIRJeff's Avatar
Default Re: where to get poly urethane radius rod bushings??? (crooked muffler)
i have stock bushings and no hop what kind of motor mounts you got
Old Feb 18, 2008 | 04:14 PM
Default Re: where to get poly urethane radius rod bushings??? (EF9SIRJeff)
Prothane front and rear inserts...
Exedy clutch
Old Feb 18, 2008 | 05:19 PM
EF9SIRJeff's Avatar
hmmm shouldnt be that bad with poly in your motor mounts check energy suspension they make just about everything your could want in bushings not sure what their site is though
Old Feb 18, 2008 | 05:52 PM
hellbound_hayride's Avatar
should be able to get them from energy suspension. otherwise there is a brand Super pro that do them. I run Whiteline adjustable radius arm kit, works mint, 7-8 degrees of caster
Old Feb 18, 2008 | 07:28 PM
higgunscrx's Avatar
es makes them, but there called strut rod bushings on their site part number: 16.7102
http://www.energysuspension.com/pages/hon1.html
i thought they didnt make them but i bought the master set and the instructions for the strut rod bushing is what we call radius rod bushings.
Old Feb 18, 2008 | 07:40 PM
gospeedgo1's Avatar
Default Re: (higgunscrx)
the radius rod bushings. password jdm has them. summit racing has them listed on ebay also.
http://passwordjdm.com/Innovat....aspx
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Feb 18, 2008 | 08:50 PM
Default Re: (gospeedgo1)
hey thanks everyone
those password jdm ones look pretty serious
ill prolly go with the energy ones tho....
i found them b4 on ebay, but like stated theyr listed as strut rod bushings
Old Feb 18, 2008 | 08:53 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crooked muffler &raquo;</TD></TR><TR><TD CLASS="quote">where to get poly urethane radius rod bushings for EF chassis???
someone link me </TD></TR></TABLE>
radius rod bushings are not the cause of wheel hop.
engine mounts are.
stiffen your engine mount. specifically the front engine mount. you can do it by numerous ways. poly inserts from ES, filling it with 3M window weld or bits of rubber, or a complete aftermarket front mount.
ive changed my radius rod bushings with poly. didnt do anytihng. filling the front engine mount with rubber is what worked.
https://honda-tech.com/zerothread?id=1124506
Old Feb 18, 2008 | 08:56 PM
Default Re: where to get poly urethane radius rod bushings??? (Tyson)
read thread
i hav both front and rear inserts already
Old Apr 22, 2009 | 01:14 PM
norurb's Avatar
Just to add some info to this older thread...Autozone sells the ES radius rod bushings (they call it Strut Rod Bushings). I paid $13.99 for the left/right side bushings.
Old Apr 23, 2009 | 03:34 AM
Hondaisok's Avatar
engine mounts are.
Question: will changing or adjusting your radius rods alter the front end alignment?
I have a bent radius rod that has been that way for 3 years and I got a front end alignment after it was bent.
Old Apr 23, 2009 | 03:59 AM
fireant's Avatar
Yes, it will change your caster. You can shim one of the rod it a little with a washer to even it out some. Its something you'd have to do between two alignments to get it right.
ES poly bushings can be ordered in at Autozone or just about any auto-parts place.
Old Apr 23, 2009 | 04:58 AM
crxmadness's Avatar
Innovative mounts
http://www.innovativemounts.com/Prod...ductCode=59103
Old Apr 23, 2009 | 05:49 AM
mjfubar101's Avatar
Wheel hop is also caused by suspension, with an adjustable shock I can make my car have wheel hop and then change it and have it go away. I also have a Full Race front traction bar. I have bent radius rods that sucked.
99teggsr
Sep 11, 2005 11:11 PM
Toretto
Aug 15, 2004 05:23 PM
eda6
Aug 13, 2004 01:40 PM
importboi22
Jul 10, 2004 12:12 PM
Burke
Dec 16, 2003 09:42 AM
