o2 sensor
on warm ups idle is good.
after driving and coming to a complete stop idle jumps from 900-1200
can the o2 be causing this. Also I dont NOt have a CEL
i checked everything. coolant system for air, iacv, etc
can the o2 cause idle problems
There is a little flat head screw at the top of your TB on the intake side tighten it up first
that can be the simplest fix for it at least it worked on mine
otherwise IACV and MAP can cause that as well if you open up your IACV and tighten up the inside that will help smooth it a small bit also (again speaking from working on my own car)
CrxSi707
May 1, 2003 11:41 AM
kHoA DoGG
Oct 31, 2002 11:44 AM
