Greddy TD05H-18G turbo wastegate actuator size question
Hello all, I have a greddy turbo kit that i am going to putting on my jdm gsr motor. From what I have found so far I know that my motor is 10.6:1 compression and that the stock wastegate on this greddy TD05H-18G turbo is 0.50-0.60kg/cm2 thats 7.5 to 8.5 psi. what i was wondereing if there is any other wastegate that I could use with this setup to lower the spring pressure to more like 5-6psi and control it using the boost controller from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOC-US2K »</TD></TR><TR><TD CLASS="quote">Hello all, I have a greddy turbo kit that i am going to putting on my jdm gsr motor. From what I have found so far I know that my motor is 10.6:1 compression and that the stock wastegate on this greddy TD05H-18G turbo is 0.50-0.60kg/cm2 thats 7.5 to 8.5 psi. what i was wondereing if there is any other wastegate that I could use with this setup to lower the spring pressure to more like 5-6psi and control it using the boost controller from there.</TD></TR></TABLE>where did you find the info on the wastegate? i had talked to greddy and they told me it was an 11psi spring.
good question how much psi is on the stock wastegate ? 7 or 8 psi my car has an 18g on it and im boosting at 12 to 14 psi on the stock wastegate with no boost controller somethings wrong ? im also getting what feels like boost cut at about 4500 rpms at WOT but if i only push the pedal half way and keep boost under 10 psi i can rev through fine any ideas ?? and yes im running a 3 bar map sensor and my ecu is chipped for it i was thinking a bad wastegate actuator......
No, we would rather you do your research.
There is no "one size fits all" answer.
Available in 4 sizes and various spring rates.
Tetsuwan Atomu
Nov 15, 2002 12:05 AM
