Towing a crx... with a crx.... across the US lol !help!
Smells like Tuna
I remember seeing somebody on hT a long time ago that had 2 crx's, 1 was used to tow the autoX crx to racetracks etc... Who was that?
I'm wondering what kind of hitch I would need to tow a rolling crx shell with my crx halfway across the US.
Otherwise what would be the cheapest route to get a crx shell from SoCal to Chicago?
Is it possible to do it <$500?
The distance is almost exactly 2,000miles lol I could be off my rocker on this. But I really want a rust free shell.
Smells like Tuna
basically what i want to do is drive halfway across the US in my crx one last time before i retire her, bring a buddy along for help, pay him in food, and pull a rolling shell back with my crx.
is that even possible? lol
i think you can buy a bolt up one. you can for the 87's because i had an 87 that got wrecked
and it had a tow hitch on it when i got it.
Smells like Tuna
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">I don't believe it</TD></TR></TABLE>
believe it lol
this is what happens when you are unemployed.
believe it lol
im sure you could get a hitch put on your rex, probably have to be custom tho. (might be expensive)
then drive there and get a uhaul car dolly and bring it back with that.
good luck.
good luck.
I've done this with rabbits, and I've also pulled stuff with my civic. It will work, but keep the speeds way down. The back end of a crx isn't heavy enough to battle the front end of one in intense maneuvers.
Smells like Tuna
any idea on a hitch setup, or a small front wheel dolley?
DrawTite makes one that bolts right up no interference problems.
27\28000 Series Fixed Tongue PN 27093
Part Number: 27093
Description: 27\28000 Series Fixed Tongue
Class Rating: CLASS I
WC: 2000
Box Size: 1¼" x 1¼"
Part Number: 27093
WC: 2000
Box Size: 1¼" x 1¼"
Why dont you contact a car shipper. Its usually $500-750 across the US and you dont have to do any work
Smells like Tuna
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">Why dont you contact a car shipper. Its usually $500-750 across the US and you dont have to do any work</TD></TR></TABLE>
Thought about it. I tried callin Hmotorsonline to see if they had any incentive but the line was busy all day. UPS freight said $1,200 and 4 days. DAS freight said 450 and 12 days. Other carriers wont even take a car that doesn't run under its own power. Alot of carriers jack the price up several hundred just to have it offloaded with a power lift truck. Even though the crx wont even fit on a power lift of any freight truck. I would almost not rather trust the damages that could happen trusting an outside freight shipping company ive never done business with before. Even tho the possibility of something happening driving across the US in a crx and pulling one back is much greater. At least i feel I have more control over the situation.
I think it would be much more fun and an awesome time driving halfway across the US in a crx to california, to get a crx and pull it back halfway across the US to chicago.
Smells like Tuna
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok »</TD></TR><TR><TD CLASS="quote">use us
$775 to chicago
rcgauto.com</TD></TR></TABLE>
interesting, where are you guys located and how would you guys go about shipping a rolling chassis?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">You better have some big brakes and a torquey b20 under the hood of the tow vehicle </TD></TR></TABLE>
how about a d15b with teh VTEC and stock brakes? lol were talkin about pulling a gutted, stripped bare crx rolling chassis, not a 40' boat
$775 to chicago
Smells like Tuna
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Buddy of mine has a tow hitch on his CRX that he thinks is ugly and wants to get rid of it. He is in VA. If you want it, I could give you his contact info.</TD></TR></TABLE>
how does he have it bolted to the crx? and what is the weight limit on it
the ones uhaul sells for $119 say max weight limit is 1,000lbs
Heres pix of my roomys hitch on his hatch which is a 91 si btw its a lil dirty but you get the picture, not sure where he got it i would ask but hes out of town til later tonight
Looks like a direct bolt up with no modification
Modified by EF9SIRJeff at 5:10 PM 2/18/2008
Dude definitley do it. That sounds like a blast. We used to use my buddys civic to haul tons of ****. We even put two complete d16z6's in the hatch area and the exhaust rubbed on the ground for about 120miles until it finally wore the flange off. I say Just do it!
Smells like Tuna
I looked at prices on small car tow dolly's at $800-1,000 thats not gonna happen Im not going to buy one just to use it once.
Although im pretty sure this is very possible to do. Looks like its going to be the best route. A bolt on hitch with a small car tow dolly.
My only hang up with this situation in trying to keep the price on doing this as cheap as possible is the cost of a car tow dolly, weather i buy one, or rent one. Renting seems like its going to be a couple hundred dollars, thats if I can lie to a rental place about the vehicle I will be using to tow the crx with.
Although im pretty sure this is very possible to do. Looks like its going to be the best route. A bolt on hitch with a small car tow dolly.My only hang up with this situation in trying to keep the price on doing this as cheap as possible is the cost of a car tow dolly, weather i buy one, or rent one. Renting seems like its going to be a couple hundred dollars, thats if I can lie to a rental place about the vehicle I will be using to tow the crx with.
