si distributor plug
Old Feb 18, 2008 | 10:38 AM
thedudefromjerz's Avatar
Default si distributor plug
Hey guys I have a depinned si distributor plug im using for my mpfi swap. Can somene post a picture of the harness side si dizzy plug. I need to see what wires go where from my dx harness. thanks alot
Old Feb 18, 2008 | 12:40 PM
Default Re: si distributor plug (thedudefromjerz)
or can someone make a diagram of the wires and colors on the si plug
Old Feb 18, 2008 | 06:12 PM
bagpipe goatee's Avatar
http://rywire.com/store/faqdes...6747d Here is what we just used. Worked. I know it's not exactly what you asked for, but it should help.
Old Feb 18, 2008 | 07:46 PM
Default Re: (bagpipe goatee)
no, that does help thanks i apreciate it.
Old Feb 18, 2008 | 07:53 PM
twiztid17thninja's Avatar
Yeah, just remember that the "normal si pinout" is in the middle. I think the dohc zc is different, which is the reason for switching those four wires around. Since we used an SI distributor, the middle one worked perfect.
(this is bagpipegoatee posting on my friend's computer)
Old Feb 18, 2008 | 08:15 PM
Default Re: (twiztid17thninja)
I have a d15b motor im converting to mpfi so im going to pin my plug following the bottom guide . what u think?
Old Feb 20, 2008 | 08:53 AM
Default Re: (thedudefromjerz)
you are sohc so use the normal si pinnout
bseriesboosted
Feb 4, 2004 09:56 AM
Kilohead36
Oct 19, 2003 10:48 AM
JustLooking
Oct 9, 2003 10:10 PM
civteg1
Nov 11, 2002 10:06 AM
ahc'monracing
Sep 14, 2002 04:32 AM
