mini-mw swap questions
Old Feb 18, 2008 | 09:40 AM
soodominican's Avatar
Default mini-mw swap questions
so i was in the
CRX & Civic FAQ Version 2.0 thread doing some research on mini-me swaps but everything says d16a6 which is the EF si motor as we all kno using a d16z6 head.... but what about a d15b2 (sohc non-vtec) with an a6 or z6 head?? anyone done this before? can u help me out? cause a dpfi>mpfi + obd0>obd1 swap is 300 dollars which i dont happen to have right now.
thanks
Old Feb 18, 2008 | 09:50 AM
EF9SIRJeff's Avatar
Default Re: mini-mw swap questions (soodominican)
well you can rule out an a6 head those dont have vtec defeating the purpose of mini mes
and you dont have to swap to obd1 to go mini me just use your same dizzy and youll be strait on that
but you will definently need to get out of the DPFI and into MPFI requiring a resistor box and some wiring to be done and youll need to pin out your ecu for vtec wires which im sure theres a write up on that in here somewhere wiring isnt my specialty
Old Mar 10, 2008 | 06:35 PM
scubascrx's Avatar
Default Re: mini-mw swap questions (EF9SIRJeff)
If the mpfi swap is already done, What more needs to be done other than putting the head on and wiring. And what mods need to be done to the head gasket?
CaliStreetWolf
Mar 22, 2013 11:40 PM
bobash69x2
Jan 27, 2008 07:42 PM
Cashieboi
Feb 11, 2006 12:59 AM
poundedhatchcrap
16
Aug 29, 2005 02:56 AM
